El Camino Central :: Search
Search found 10 matches
El Camino Central Forum Index
  Topic: front coil spring help!!!!
69elbamabino
PostForum: Suspension   Posted: Fri Nov 07, 2008 10:13 pm   Subject: thanks for the info
thanks for the feedback. It's great having folks like you on the forum. Trial and error only gets you so far sometimes. Thanks again. I really appreciate it.
  Topic: body bushing questions
69elbamabino
PostForum: Suspension   Posted: Fri Nov 07, 2008 10:10 pm   Subject: Thanks for the info
I really appreciate the words of wisdom. I will get after it this weekend and hopefully get it done.
Thanks again.
69elbamabino
PostForum: Suspension   Posted: Thu Nov 06, 2008 10:42 pm   Subject: body bushing questions
replaced the front body bushings (radiator support bushings) because they were toast. it was cheaper to buy the whole set but......
how do you replace the mid and rear bushings without taking the b ...
69elbamabino
PostForum: Suspension   Posted: Thu Nov 06, 2008 10:28 pm   Subject: front coil spring help!!!!
anyone have real experience changing out the front coil springs on a 3rd gen el camino?thought replacing the front shocks and coil springs was going to be challenging but do-able. shocks are out. disc ...
  Topic: AAAhhhhh, a lilttle help...........
69elbamabino
PostForum: Interior Restoration   Posted: Sat Aug 16, 2008 12:51 pm   Subject: AAAhhhhh, a lilttle help...........
ebay - i bought a 1969 chevelle and el camino factory assembly manual. plan on paying 20 bucks if they have your year. so far it has easily been worth the money. these manuals are copies of the manual ...
  Topic: 327 75cc heads on a 350
69elbamabino
PostForum: Engine Topics   Posted: Tue Aug 05, 2008 2:14 pm   Subject: thanks for the info
i will look for the heads you mentioned.
the ones my mechanic has are 3876775 which come up 1960-67 for 283 / 327 engines w/ 75cc.
my old heads were 64cc heads on a 350, delivering 10.5 - 1 co ...
69elbamabino
PostForum: Engine Topics   Posted: Tue Aug 05, 2008 12:07 pm   Subject: 327 75cc heads on a 350
i have a 69 el camino with a 350 which has had a lot of head issues, bent & busted push rods, and then some. my mechanic has found some "pristine" heads off i believe off a 67 chevelle for $300 (m ...
  Topic: suspension help!!!!
69elbamabino
PostForum: Suspension   Posted: Tue Jul 29, 2008 11:15 am   Subject: suspension help!!!!
i have a 69 el camino 350 / 4sp, currently w/ out AC but plan on reassembling AC. This a cruiser, not a drag strip car.
The front suspension needs help. I was planning on replacing, front and back, ...
  Topic: Dynamat finally finished....PICTURE
69elbamabino
PostForum: Interior Restoration   Posted: Wed Jul 16, 2008 6:37 pm   Subject: how much did you use?
i found the bulk packs (9 panels / 36 sq ft) on ebay and bought one for a $120; pretty cheap compare to other sources. the guy at dynamat said one bulk pack should be plenty for the floors, doors, and ...
  Topic: best door panels
69elbamabino
PostForum: Interior Restoration   Posted: Wed Jul 16, 2008 6:28 pm   Subject: best door panels
any opinions on who make the best quality replacement door panels? i was referred to legendary auto interiors our of new jersey by someone who "heard" they were good. seems like they are readily avail ...
Page Generation: 0.292 Seconds
