I installed the ignition switch on the steering column, still nothing. I'm wondering if I have to install the whole instrument panel because im trying to start it with the instrument panel off.
I have a 1980 El Camino with a 305. It does not start at all the starter doesnt even turn over. I bench tested motor and solenoid both passed. I found no power going to the solenoid and no power comin ...
I was looking to install a mini spool in my 10 bolt. I was wondering by just installing the mini spool would it lock both wheels (posi)? Thats what ive come to understand. I was gonna change the ring ...
I have a problem on my 1980 el co 305, when I turn the ignition to start it nothing happens no crank nothing. The problem started when I was fixing my lights I saw a purple wire just hanging there so ...
Checked wires at starter solenoid and one of them was cut. So i purchased a new fusible link and solderd it hooked up and all lights worked great. Thanks alot
I HAVE A 1980 EL CAMINO 305. I HAD THE ENGINE REBUILT AND AFTER I GOT THE CAR BACK NOTHING WORKED. HEADLIGHTS, TAIL LIGHTS BRAKE LIGHTS, REVERSE LIGHTS, DASH LIGHTS, DOME LIGHT, HORN, DOOR CHIME. THE ...
