El Camino Central :: Search
Search found 49 matches
El Camino Central Forum Index
  Topic: Windshiel fit question
ACZ66
PostForum: Body Restoration   Posted: Thu Oct 16, 2008 9:30 pm   Subject: Windshiel fit question
Does anyone know if a windshield out of a 66 olds delta 88 would fit a 66 el camino. i don't even know what a 66 delt 88 looks like, but there is a free windshield about 2 hours from me! let me know t ...
  Topic: Sound System for a 1966
ACZ66
PostForum: Audio   Posted: Fri Jul 04, 2008 7:09 pm   Subject: 66 stereo
I have a 66 as well, I drove it daily back in the 90's, it sat for 10+ years, and I recently got it back on the road. Anyway, I replaced all of the (Cool speakers I had in it, due to deterioration, etc. ...
  Topic: repair manual for 66
ACZ66
PostForum: Tips & Tricks   Posted: Wed May 21, 2008 8:41 am   Subject: repair manual for 66
any thoughts on what the best book is out there to get for resto work on a 66? I would like a Hayes/Chilton's type that goes step by step through with pix. Basic stuff, like front end, wiring diagrams ...
  Topic: Window Sweeps Removal
ACZ66
PostForum: Tips & Tricks   Posted: Fri May 16, 2008 3:13 pm   Subject: Window Sweeps Removal
any tips on removing/replacing them for a 66? I did it on a 72 c20, and what a difference it makes to have some that work! but they didn't come out too straight. are there some tricks to this or do yo ...
  Topic: Brake light and fuse panel
ACZ66
PostForum: Electrical Systems   Posted: Fri Apr 18, 2008 10:37 am   Subject: Brake light and fuse panel
finally received turn signal switch, it was on back order. installed and everything SEEMS to be working fine. We'll see. unclemino is back on the road! drove to work today, things are slowly getting b ...
ACZ66
PostForum: Electrical Systems   Posted: Tue Mar 18, 2008 10:26 am   Subject: Brake light and fuse panel
Removed switch, now need to order a replacement. Any suggestions? I haven't found one for less than $65 yet. Thanks!! AC
ACZ66
PostForum: Electrical Systems   Posted: Sun Mar 09, 2008 10:32 pm   Subject: Brake light and fuse panel
Pressed brake while messing with blinker. Brake light was flickering on/off. Makes me suspect the turn sig. switch, as sugested. Now, how do I remove it? I have the st. wheel off, but don't know how t ...
ACZ66
PostForum: Electrical Systems   Posted: Fri Mar 07, 2008 12:13 pm   Subject: Brake light and fuse panel
Thank you guys, I will give it a shot this weekend. Where is the ground I should be checking? Is is on the back of the fuse block to the firewall, or somewhere else. Any info i helpful. Thanks again, ...
ACZ66
PostForum: Electrical Systems   Posted: Thu Mar 06, 2008 12:33 pm   Subject: Brake light and fuse panel
66 EC, nothing stock, except original pains in the a$$. Driver's side rear brake light working occassionally. It has a mind of it's own. Where do I start? The bulb is good. Along the same line, does a ...
  Topic: wiper motor/switch problems, please help!
ACZ66
PostForum: Electrical Systems   Posted: Wed Dec 26, 2007 10:32 pm   Subject: wiper motor/switch problems, please help!
thanks for the heads up, it sounds very similar to the 72 i'm (trying) to work on. Holidays...no time!!! thanks again, I think the wires may be connected wrong or the switch is bad, can't wait to tear ...
  Topic: Quality tuner (redding)
ACZ66
PostForum: Region 18 (N.CA,N.NV)   Posted: Tue Nov 27, 2007 10:10 pm   Subject: Quality tuner (redding)
Howdy y'all. I'm looking for some one or a shop in Redding or near by that is good with old cars. My ec has a 350 w/ q jet, 4 speed. New HEI dizzy. I want some one who can dial it in. I don't want to ...
  Topic: nor cal (region 18) roll call!!!
ACZ66
PostForum: Region 18 (N.CA,N.NV)   Posted: Tue Nov 27, 2007 8:08 pm   Subject: nor cal (region 18) roll call!!!
I'm in Redding. 66, 350 4sp, 2-70 A/C, old paint, terrible interior, but love it to death. Had it since 1989, just got it running this summer, it had been in storage for 7 years. Boy, does that ruin t ...
  Topic: work with this mess they called wiring...or not??
ACZ66
PostForum: Electrical Systems   Posted: Tue Nov 27, 2007 8:01 pm   Subject: work with this mess they called wiring...or not??
First of all, I can be of no help. I just want to say I feel your pain, and good luck. I have two project vehicles and electrical problems abound in both. Nothing can ever be easy, ya know. Let us kno ...
ACZ66
PostForum: Electrical Systems   Posted: Tue Nov 27, 2007 7:50 pm   Subject: wiper motor/switch problems, please help!
66. the wipers only come on when I hold in the washer pump button. nothing on low or high, they just move really slow when i hold the button in. any ideas? i am also trying to get a wiper motor workin ...
  Topic: Help w/wiring HEI conversion
ACZ66
PostForum: Ignition Upgrades & Discussion Forum   Posted: Tue Sep 18, 2007 11:03 am   Subject: Help w/wiring HEI conversion
OK, traced the wire to the firewall terminal, left about 3" and cut the rest off, connected 12g wire to send to new dizzy cap. Took out old dizzy, new one wouldn't seat. Let me go back, I didn't take ...
Page 1 of 4 Goto page 1, 2, 3, 4  Next
Page Generation: 0.317 Seconds
