El Camino Central :: Search
Search found 38 matches
El Camino Central Forum Index
  Topic: inst.cluster pod swap question 87 to 84
CF
PostForum: Electrical Systems   Posted: Thu Oct 30, 2008 9:12 am   Subject: inst.cluster pod swap question 87 to 84
sorry guys i forgot to mention that i have gauges and the clock now.thanks doug.
CF
PostForum: Electrical Systems   Posted: Wed Oct 29, 2008 4:31 pm   Subject: inst.cluster pod swap question 87 to 84
sorry guys i did read alot of things when i did my search first, but i need to clesr 2 things up. i got a 84 e/c with a clock no tach.my question is will a inst. cluster from a 87 m/c sswith a tach in ...
  Topic: battery tray swap from 87 m/c ss question
CF
PostForum: Body Restoration   Posted: Wed Oct 22, 2008 5:45 pm   Subject: battery tray swap from 87 m/c ss question
thanks Ernie i think i should visit the guy parting off the m/c again.im guessing that there is alot more i could use.while i was there getting the buckets i took the inst. cluster w/ tach.im hopeing ...
  Topic: EC Store Tachometer Kit Question
CF
PostForum: Electrical Systems   Posted: Wed Oct 22, 2008 4:18 pm   Subject: EC Store Tachometer Kit Question
so the resistor or whatever is not necessary? can i go direct with reg. wire to the tach. conn. on my dist. ?thanks carl
CF
PostForum: Body Restoration   Posted: Wed Oct 22, 2008 4:09 pm   Subject: battery tray swap from 87 m/c ss question
will it work? does the batt. tray from 87 m/c ss fit a 84 e/c ? thanks carl
  Topic: cleaning up stainless moulding question?
CF
PostForum: Body Restoration   Posted: Thu Oct 16, 2008 10:37 am   Subject: cleaning up stainless moulding question?
what will the oven cleaner do?anyone tried this ?i will most likely have to replace these pieces from the sounds of things but im willing to try a easy fix out of curiosity.thanks.
CF
PostForum: Body Restoration   Posted: Tue Oct 14, 2008 8:55 pm   Subject: cleaning up stainless moulding question?
looks like ill have to find new ones. thanks to all.
CF
PostForum: Body Restoration   Posted: Tue Oct 14, 2008 4:44 pm   Subject: cleaning up stainless moulding question?
i give up on all these rub on miracle cleaners. my wheel arch trim looks like oxidized aluminum.maybe it is.does anyone have a solution to really cleaning this white haze off?thanks carl
  Topic: sport side view mirrors question for 84
CF
PostForum: Body Restoration   Posted: Wed Oct 01, 2008 6:50 pm   Subject: sport side view mirrors question for 84
thanks 87e/c do you think that penetrating oil will mess up the mirror backing? i did try some wd40 the other day but i think it sprayed all the way back,maybe ill take off the tube this time,maybe il ...
CF
PostForum: Body Restoration   Posted: Wed Oct 01, 2008 6:25 pm   Subject: sport side view mirrors question for 84
hi, does the pass. side adjust by a remote cable like the d/s or is just manual adjust with your fingers? either way mine wont budge and i need to move it from the previous owners needs. any help on l ...
  Topic: what doors will interchange with a 84 ?
CF
PostForum: Body Restoration   Posted: Mon Sep 08, 2008 7:59 pm   Subject: what doors will interchange with a 84 ?
can anyone tell me exactly what door will go on my 84.,cutlass?,malibu ?who can tell me for sure so i know what to search the bone yard for. thanks
  Topic: what will have to be done to make this work?
CF
PostForum: Transmission & Drive line   Posted: Mon Sep 01, 2008 7:24 pm   Subject: what will have to be done to make this work?
hi.i want to change from the column shifter to a reg, factory floor shifter so everything looks stock. i have a 84 with a 350 tranny center console,shifter, cable and brackets from a m/carlo it looks ...
  Topic: how to remove clear silicone from chrome trim?
CF
PostForum: Body Restoration   Posted: Thu Aug 28, 2008 9:27 am   Subject: how to remove clear silicone from chrome trim?
doug, thank you. i will try it .thank you.
CF
PostForum: Body Restoration   Posted: Fri Aug 22, 2008 8:42 pm   Subject: how to remove clear silicone from chrome trim?
hi, some clown used silicone on the facing of the moulding on the roof (probaly had a cap at one time) and i want it off. it wont peel off and i dont want to scratch the moulding .what do you guys rec ...
  Topic: 5th gen column to floor shifter
CF
PostForum: Transmission & Drive line   Posted: Mon Aug 18, 2008 7:58 pm   Subject: 5th gen column to floor shifter
hi, was going to change mine from column to floor shift also but now i need to clarify a thing or two. maybe you guys can get me straight on this,i have a floor shifter and cable,console from a m/carl ...
Page 1 of 3 Goto page 1, 2, 3  Next
