El Camino Central :: Search
Search found 26 matches
El Camino Central Forum Index
  Topic: X,H or neither?
Cmino
PostForum: Performance Modifications   Posted: Fri May 16, 2008 12:16 pm   Subject: X,H or neither?
I agree with rbohm. I'm gettin ready for a new 383 engine and 2.5" dual exhaust. An ex-stock car driver just told me the H pipe for my modified daily driver will bump the horse power a few horses. ...
  Topic: Made donation, no acknowledgement, no thank you, etc
Cmino
PostForum: Site Topics   Posted: Sat Jul 14, 2007 7:27 pm   Subject: Made donation, no acknowledgement, no thank you, etc
I've been waiting over 3 weeks for confirmation on the ECC side after also donating thru PayPal. I've been stiffed out of dollars many times over 36 years so no confirmation gets me concerned to say ...
  Topic: Help me pick paint colors for a 5th Gen Conquista
Cmino
PostForum: Body Restoration   Posted: Thu Jun 21, 2007 8:11 pm   Subject: Help me pick paint colors for a 5th Gen Conquista
#4
See the cover of the El Camino 1978-87 catalog from Original Parts Group (cat # LM2002). The Cmino on the cover is blue but I think it will be obvious why #4.
The fact that my '83 (parked) and ...
  Topic: Bouncing New Suspension
Cmino
PostForum: Suspension   Posted: Mon Mar 12, 2007 9:15 pm   Subject: Bouncing New Suspension
Problem reduced but not solved. Without directions with new springs I installed as stock with flat coil at top. This flipped the wording on the springs upside down which I later learned is wrong. I ...
Cmino
PostForum: Suspension   Posted: Sat Feb 24, 2007 12:05 pm   Subject: Bouncing New Suspension
There is a measured 1.75" shaft showing. Bilstein finally confirmed 4.92" shock travel. 1/3 of 4.92" is 1.64" which puts me almost 1/8" on the plus side. But maybe this model Bilstein needs to be ne ...
Cmino
PostForum: Suspension   Posted: Wed Feb 21, 2007 8:12 pm   Subject: Bouncing New Suspension
Well I loosened the C.A. pivot bolts, bounced the Cmino a few times, then re-tightened. It helped but only slightly. Then I put the old shocks back on and it helped a little more but truck still bou ...
Cmino
PostForum: Suspension   Posted: Mon Feb 12, 2007 10:29 pm   Subject: Bouncing New Suspension
Very possible that tightening the control arm bushings without vehicle weight is playing at least some part in this. When I replaced the rear springs and disconnected the upper control arms from the ...
Cmino
PostForum: Suspension   Posted: Mon Feb 12, 2007 4:35 pm   Subject: Bouncing New Suspension
The Springs are progressive.
Cmino
PostForum: Suspension   Posted: Sun Feb 11, 2007 3:15 pm   Subject: Bouncing New Suspension
The truck still has the tired original V8 engine so no extra weight. I don't believe these shocks are adjustable.
Pack Rat, I agree, the part number needs to end with a '+' sign as recommended for ...
Cmino
PostForum: Suspension   Posted: Sat Feb 10, 2007 12:18 pm   Subject: Bouncing New Suspension
Weight of truck used only for shock tighteningl but tires were off for all ball joints, tie rods, idler arm, and drag link installs. I didn't think it was an issue. I believe when you are tightening ...
Cmino
PostForum: Suspension   Posted: Thu Feb 08, 2007 10:35 pm   Subject: Bouncing New Suspension
Frustrating front end bounce on my '87 Chevy El Camino with the following new parts just installed:
- Bilstein shocks P/N F4-B36-0949-HD
- Eibach Pro Kit 1" lowering springs
- Tubular upper con ...
  Topic: speedo help
Cmino
PostForum: Transmission & Drive line   Posted: Wed Mar 22, 2006 5:25 pm   Subject: speedo help
Here's another related link.
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
  Topic: speedo help
Cmino
PostForum: Transmission & Drive line   Posted: Tue Mar 21, 2006 7:38 pm   Subject: speedo help
I believe jayachtee is on target. After I had my '87 200r4 rebuilt my speedo was off about 5mph too high at 30mph and off 10mph at 45mph. I forgot to tell them I changed the rear gears. They then put ...
  Topic: Intake Manifold from idle or 1500rpm
Cmino
PostForum: Engine Topics   Posted: Fri Feb 17, 2006 1:22 am   Subject: Intake Manifold from idle or 1500rpm
With Cmino rear so light and my driving habits requiring action in the 20-55mph range, does an intake manifold rated for 1500-5500rpm make more sense than idle-6500rpm? For stock 305 w/600cfm carb, mo ...
  Topic: Temp Tach/voltmeter hookup
Cmino
PostForum: Electrical Systems   Posted: Tue Feb 07, 2006 11:05 am   Subject: Temp Tach/voltmeter hookup
Hey thanks guys. Now hopefully I can get this thing running right away to properly break in the cam and not damage it. Before the new parts, it was very difficult to get the rockers adjusted so the ...
Page 1 of 2 Goto page 1, 2  Next
Page Generation: 0.465 Seconds
