| Author |
Message |
Topic: reverse is grinding |
Forum: Transmission
& Drive line Posted: Wed Dec 03, 2008 7:58 pm Subject: reverse is grinding |
You said it yourself ~~ Have it looked at, something is wrong, and when something is wrong and not repaired, it always leads to BIGGER and COSTLIER issues.
Just my thoughts on the matter. |
Topic: Backfire & Hesitation? |
Forum: Engine
Topics Posted: Tue Dec 02, 2008 7:19 pm Subject: Backfire & Hesitation? |
| Maybe you've already checked, but ~~~ with alot of rain fall, is it possiable you may have moisture inside the Dist. Cap. Just a guess at this point, but I have seen it when it rains, even though the ... |
Topic: Strange muffler like sound coming from Tranny? |
Forum: Transmission
& Drive line Posted: Tue Dec 02, 2008 7:04 pm Subject: Strange muffler like sound coming from Tranny? |
I concure with what Jim has said. I would look for an exhaust leak, exhaust manifold gasket or maybe the doughnut at the header pipe.
That would be the the first area of inspection. |
Forum: Engine
Topics Posted: Tue Dec 02, 2008 4:55 am Subject: Backfire & Hesitation? |
To further explane, and other things to check AS WELL as give you something to read~~~~~~
"Backfiring" is a condition described as a loud bang, poof, explosion, etc. when idling the engine down, ... |
Forum: Engine
Topics Posted: Tue Dec 02, 2008 4:32 am Subject: Backfire & Hesitation? |
Some things to check
Check for air leaks. Make sure carburetor and manifold gaskets seal properly. All outlets must be plugged or connected.
Check ignition system. Replace parts as necessary. Adjust ... |
Topic: seafoaming and i need help |
Forum: Engine
Topics Posted: Tue Dec 02, 2008 2:19 am Subject: seafoaming and i need help |
| This is the Engine compartment of a 77, the booster is that round object on the drivers side firewall, just above the red MSD box on the drivers side fenderwell in the photo. The Brake Mastercylinder ... |
Topic: Wandering front end on 85 Elco (cost estimate to replace) |
Forum: Suspension Posted: Tue Dec 02, 2008 1:52 am Subject: Wandering front end on 85 Elco (cost estimate to replace) |
| Mostley your loking for the laminated material to be bad, oil soaked, torn, rotted. it is composed very similar to auto tires, missing fasteners, and overall condition. Not bad or difficult to replace ... |
Topic: Need help deciding color. |
Forum: General
BS Topics Posted: Mon Dec 01, 2008 10:06 pm Subject: Need help deciding color. |
| Orange is a great color with the Black, even though it's NOT one of the two colors you had asked about. I'm sure you will be happy you chose that color combo. We will look forward to the Photos. |
Topic: First in Class at the NY Custom Car Show |
Forum: Calendar
of Events Posted: Mon Dec 01, 2008 1:19 am Subject: First in Class at the NY Custom Car Show |
| Congrats Leo ~~~ Well Deserved I'm sure. |
Topic: Battery drain? |
Forum: Electrical Systems Posted: Mon Dec 01, 2008 1:17 am Subject: Battery drain? |
| Good :::::: Sounds like your on the right track, good luck. |
Topic: Carter AFB (flooding out cold start?) 84 Elco.. |
Forum: Engine
Topics Posted: Mon Dec 01, 2008 1:14 am Subject: Carter AFB (flooding out cold start?) 84 Elco.. |
| Again ~~~ Good Luck and keep us posted. |
Forum: Engine
Topics Posted: Sun Nov 30, 2008 4:39 pm Subject: Carter AFB (flooding out cold start?) 84 Elco.. |
Just a guess mind you, but sounds like FLOAT ISSUES to me. That would be my first look. The boiling could be just air bleed as well, they can look very similar. Again ~~ A Guess.
By the way, WELCOM ... |
Topic: 73-77 Monte Polycast wheels |
Forum: Suspension Posted: Sun Nov 30, 2008 4:31 pm Subject: 73-77 Monte Polycast wheels |
| Ralph, As you said, aircraft stripper might do the job. But if I were going to do it, I wouldn't mess with it I'd take it somewhere and just have them Bead Blasted and start with a GOOD Clean surface ... |
Topic: THE WORD "STRAIGHT" |
Forum: General
BS Topics Posted: Sun Nov 30, 2008 4:18 pm Subject: THE WORD "STRAIGHT" |
| NOT EVEN GOING THERE !! |
Topic: knocking noise when cold, cracked flexplate? |
Forum: Transmission
& Drive line Posted: Sun Nov 30, 2008 4:13 pm Subject: knocking noise when cold, cracked flexplate? |
| That would only be a guess at this point, my first thought is, what grade of oil are you running, and I'm sure you have had a temp. drop where your located. Sounds as if the oil is a little on the thi ... |
