My last six digits are "141791". Is that line number 41,791, or line number 1791, or 791, etc, etc. According to the vin decoder here there was only a little over 30K produced in 64.
How do I get the crank shaft gear off the crank? I am doing some work to my motor and need to remove my crank shaft gear and cam shaft gear. The cam gear came off very easily, but I can't get the cran ...
I have a 64 El Camino. 327, 4 speed, stock except edlebrock carb. I really like the sound of gear drive, but no nothing about it. If I want to add gear drive what negative affects will I have on a dai ...
Has any one ever had a stock, original, headlight switch/dimmer switch ground out and blow fuses? I am having problems with my switch blowing fuses when pulled on. I think I may have trouble shot my f ...
I have a 64 and would like to put some 15" x 7" rally rims on. Does anyone know of any size restrictions on rims and tires for a 64? I currently have 14" cragars, tire size currently slips my mind.
