I managed to post a couple of before pictures but the two after pictures just errored out. Can anyone help me because the after pictures are certainly better than the before.
Thanks for the info, I guess there is no better way to do it. I will have to trim the larger piece that goes under the door skin also since it is too long. Like you say just go slowly and cut a litt ...
Any good carwash soap and then Klasse All-In-One with multiple coats of PS21 wax. I use that on my Lemans Blue Vette and the shine is way better than anything i've used before (Mother's, Classic, Men ...
I need some help in installing my door weatherstripping. The two snaps at the top front of the door match up nicely but the rubber part toward the front of the snaps is too long to fit sluggly agains ...
I was changing out my heater core and when I pulled all the rubber caulking off from around it I found that the cover was cracked in two places and the whole left corner was broken off. Anyone have a ...
