El Camino Central :: Search
Search found 6 matches
El Camino Central Forum Index
  Topic: rear end ???
Ebbsspeed
PostForum: Transmission & Drive line   Posted: Mon Jul 21, 2008 4:47 pm   Subject: rear end ???
I bought one at a swap meet here in Kansas City this spring for $400, so to me that $900 number is WAY high.........
I think $700 is more like the going rate, but if you gotta have one now, then yo ...
  Topic: 86 El Camino & 87 GN Rear - Shorten Driveshaft?
Ebbsspeed
PostForum: Transmission & Drive line   Posted: Sat Apr 12, 2008 2:49 pm   Subject: 86 El Camino & 87 GN Rear - Shorten Driveshaft?
I picked up an 87 Grand national rear axle, and will be putting it into my 86 El Camino. I need to know how much to shorten the driveshaft. If I recall, I read somewhere that it needed to be shortened ...
  Topic: 95 Camaro rear end swap into 86 El Camino?
Ebbsspeed
PostForum: Transmission & Drive line   Posted: Sun Jul 08, 2007 7:44 pm   Subject: 95 Camaro rear end swap into 86 El Camino?
A guy offered me a posi rear from a 95 Camaro, any info on whether it's a bolt-in deal, or what is required to do it? Also, did the 95 Camaro's have an 8.5 inch rear, or is it basically the same 7.5 i ...
  Topic: Did they put out posi rear-ends in '85
Ebbsspeed
PostForum: Transmission & Drive line   Posted: Tue Jul 03, 2007 9:36 am   Subject: Did they put out posi rear-ends in '85
You can jack the backend off the ground & spin one wheel. If the other wheel spins in the same direction, you have a posi. If the other wheel travels in the opposite direction, you have a single t ...
  Topic: Rainting stencils for 1986 El Camino Wheels
Ebbsspeed
PostForum: Body Restoration   Posted: Sun Feb 18, 2007 7:59 pm   Subject: Rainting stencils for 1986 El Camino Wheels
A while back I read (somewhere) where I could get pre-cut adhesive backed stencils to use for repainting El Camino rally wheels. As I do too often, I forgot where I read it, so if anyone knows where I ...
  Topic: Doors for 1986 manual and electric windows the same?
Ebbsspeed
PostForum: Body Restoration   Posted: Sun Aug 21, 2005 11:25 am   Subject: Doors for 1986 manual and electric windows the same?
I've got a chance to buy a couple of doors from a rust-free 85 El Camino, and want to put them on my 86. However, the 85 has manual windows and mine are electric. Will the doors from the 85 work with ...
Page Generation: 0.278 Seconds
