El Camino Central :: Search
Search found 388 matches
El Camino Central Forum Index
  Topic: Custom oil sender adapter...PICTURES
Elcaminonyc
PostForum: Engine Topics   Posted: Sat Nov 15, 2008 10:26 pm   Subject: Custom oil sender adapter...PICTURES
For my application its the perfect place----I want as little as possible showing to detract from the way my motor looks-as far as fuction, this is where GM put them, and I wanted to use the factory ga ...
Elcaminonyc
PostForum: Engine Topics   Posted: Sat Nov 15, 2008 9:18 am   Subject: Custom oil sender adapter...PICTURES
Building this project taught me one thing-----when you build anything custom and change a part---it effects something else...
I was unhappy with the way the stock oil sender gauge was mounting --- ...
  Topic: Trinary switch for A/C installed...PICTURES
Elcaminonyc
PostForum: Heating & Air Conditioning Systems   Posted: Sat Oct 11, 2008 1:52 pm   Subject: Trinary switch for A/C installed...PICTURES
Hey Robert,
Good to hear from you ---the problem is as follows----GM fiitings --if you want to use stock components it is a # 12---the problem is that aeroquip does not make, nor could I find anyo ...
Elcaminonyc
PostForum: Heating & Air Conditioning Systems   Posted: Fri Oct 10, 2008 10:23 pm   Subject: Trinary switch for A/C installed...PICTURES
A/C almost finished.......installed the trinary Switch -----this is a must and made to protect your AC compressor from running when the refrigerant pressure is either too high or too low.........wante ...
  Topic: Hole placement for 86-88 mirrors
Elcaminonyc
PostForum: Body Restoration   Posted: Sun Sep 28, 2008 10:25 am   Subject: Hole placement for 86-88 mirrors
I have the same issue that you do---have not done it yet --but a fellow club member sent me this info-----
"I can tell you where the mirror bases are located on my '87. The front point of the mir ...
  Topic: Custom Braided A/C lines----PICTURES
Elcaminonyc
PostForum: Heating & Air Conditioning Systems   Posted: Sun Sep 28, 2008 9:08 am   Subject: Custom Braided A/C lines----PICTURES
I have almost finished the custom A/C line installation---the goal was to get as many lines out of view in the engine (less clutter)---therefore, everything needed to be rerouted or hidden----for tho ...
  Topic: Inner Choo Choo nose primed PICTURE
Elcaminonyc
PostForum: Body Restoration   Posted: Mon Sep 15, 2008 9:34 am   Subject: Inner Choo Choo nose primed PICTURE
As far as inner fenders go---they are the same as the body on a Vette-----you need to prep properly and undercoat---or, you risk the posibility of stars in the paint from rocks----
As far as the H ...
Elcaminonyc
PostForum: Body Restoration   Posted: Mon Sep 15, 2008 8:15 am   Subject: Inner Choo Choo nose primed PICTURE
The primer is House of Kolor epoxy primer. You can put it under or over filler, it claims superior adhesion, and protection if used first (under your filler).Not all epoxies are like this, though. You ...
Elcaminonyc
PostForum: Body Restoration   Posted: Sat Sep 13, 2008 7:13 am   Subject: Inner Choo Choo nose primed PICTURE
Inner Choo Choo nose prepped, primed and painted---also the headlight buckets----getting ready for some 3M undercoating---hopefully next week-----working on some custom A/C brackets for braided lines- ...
  Topic: Gauges
Elcaminonyc
PostForum: Interior Restoration   Posted: Sat Sep 06, 2008 8:02 am   Subject: Custom dash
here you go ---they are beautiful---it does not get better than this....
http://www.custommontessparts.com/
Pete NYC/ATL
  Topic: What do you kids think?
Elcaminonyc
PostForum: General BS Topics   Posted: Fri Jul 25, 2008 6:32 am   Subject: What do you kids think?
Powder coating is just like paint-----it will only get to the areas that it can be sprayed on---the areas inside the frame rails are difficult to reach and therefore will probably not be coated---Howe ...
  Topic: Final glazing and sealer applied---PICTURES...
Elcaminonyc
PostForum: Body Restoration   Posted: Wed Jul 23, 2008 7:56 am   Subject: Final glazing and sealer applied---PICTURES...
Thanks all... truly appreciated-----as most of you know I relocated to Atlanta about two years ago from NYC------living here full time now---and loving it---car shows 10 months of the year------anyway ...
Elcaminonyc
PostForum: Body Restoration   Posted: Wed Jul 23, 2008 6:22 am   Subject: Final glazing and sealer applied---PICTURES...
The bed is finally ready for paint!!!!!!! The final glazing and the sealer were applied over the last week or so---now, a fiinal scuff and tacking ,and we are ready for color......................I g ...
  Topic: Dynamat finally finished....PICTURE
Elcaminonyc
PostForum: Interior Restoration   Posted: Wed Jul 16, 2008 9:14 pm   Subject: Dynamat finally finished....PICTURE
The one thing i learned is that you don't need to cover every square inch of the floor----I guess it depends on what you are looking for ---I wanted sound deadoning, but also wanted insulation for the ...
  Topic: New Concept Valve covers!!!!
Elcaminonyc
PostForum: Product Review   Posted: Wed Jul 16, 2008 9:10 pm   Subject: New Concept Valve covers!!!!
Aren't they nice-----$265.00 worth every penny !!!!!
Page 1 of 26 Goto page 1, 2, 3 ... 24, 25, 26  Next
Page Generation: 0.334 Seconds
