El Camino Central :: Search
Search found 221 matches
El Camino Central Forum Index
  Topic: 21 Sealed Semi Trailers Full of Chevy Muscle Cars and Parts!
John_Muha
PostForum: General BS Topics   Posted: Thu Dec 08, 2005 10:12 pm   Subject: 21 Sealed Semi Trailers Full of Chevy Muscle Cars and Parts!
I'd like to see some photos before I believe.
  Topic: Need some help with headlights
John_Muha
PostForum: Electrical Systems   Posted: Tue May 10, 2005 10:38 am   Subject: Need some help with headlights
Yeah, check the ground wire to the right inside fender. If that looks ok, pull the connector off the left headlight. You should be able to get at that one from under the hood. Check if there is 12 ...
  Topic: 79' dash lights/ blinkers not working
John_Muha
PostForum: Electrical Systems   Posted: Tue May 10, 2005 10:32 am   Subject: 79' dash lights/ blinkers not working
On the blinkers:
Are just the dash lights not working or are the outside lights not coming on?
  Topic: Wiring Harness Question converting Generator to Altenator.
John_Muha
PostForum: Electrical Systems   Posted: Thu Mar 17, 2005 4:02 pm   Subject: Wiring Harness Question converting Generator to Altenator.
Don't need much to convert from a generator to an alternator. Depending on what you need the alternator to do one from a late 70s A/C equipped vehicle should do it. Just get a connector for it and r ...
  Topic: no 'clicking sound' from the blinkers
John_Muha
PostForum: Electrical Systems   Posted: Thu Mar 17, 2005 3:49 pm   Subject: no 'clicking sound' from the blinkers
Wrong flasher. The one you want is under the dash between the steering column and the radio. Feel for it while it's flashing. Should be able to find it.
  Topic: My wipers are haunted!
John_Muha
PostForum: Electrical Systems   Posted: Sun Mar 13, 2005 9:55 am   Subject: My wipers are haunted!
I usually hit the junkyard and replace the whole motor assembly.
  Topic: IM 16!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
John_Muha
PostForum: General BS Topics   Posted: Sat Mar 12, 2005 10:12 pm   Subject: IM 16!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well, when you find the Elky girls of your dreams, post pictures of her momma. She may but momma has.
  Topic: 75EC: Intermitant Ignition Problem
John_Muha
PostForum: Electrical Systems   Posted: Thu Mar 10, 2005 2:21 pm   Subject: 75EC: Intermitant Ignition Problem
With your HEI distributor there is no resistor on the line going into the HEI B+ terminal. You may be right in the root cause being the input B+ (12 volts) to the HEI. Try and eliminate that as a ca ...
  Topic: Car wont start
John_Muha
PostForum: Electrical Systems   Posted: Thu Mar 10, 2005 1:55 pm   Subject: Car wont start
Do you have the ground strap for the coil? Goes inside the cap. It is the center pin of the 3 pins of the connector on the coil.
  Topic: Gas tank sending unit.
John_Muha
PostForum: Electrical Systems   Posted: Sun Feb 27, 2005 10:56 am   Subject: Gas tank sending unit.
I'd test it out before I would replace any parts. Nothing worse than spending the time and money replacing it just to find out it's an easy fix. An open sender ground, an open sender wire, or an ope ...
  Topic: Turn signal won't work.
John_Muha
PostForum: Electrical Systems   Posted: Sat Feb 26, 2005 9:55 am   Subject: Turn signal won't work.
Without grabbing a book, thought the 74 turn signal flasher is under the dash. The only one in the fuse block is the emergency flasher can.
It's located on about 10 inches of wire somewhere between ...
  Topic: can't get 69' dash to light up
John_Muha
PostForum: Electrical Systems   Posted: Thu Feb 24, 2005 11:28 am   Subject: can't get 69' dash to light up
What you can try is to remove the blown fuse. Connect a test light or an automobile light and socket across the fuse clips. A couple of clip lead may help.
Turn on the dash lights and turn the rheo ...
  Topic: HEADLIGHT WORK WHEN THEY WANT TO
John_Muha
PostForum: Electrical Systems   Posted: Sat Feb 19, 2005 11:41 am   Subject: HEADLIGHT WORK WHEN THEY WANT TO
Checked all the grounds out. Found a few wires that were a little shady and replaced. Headlights are (for now) staying on. But the messed up thing is I can have my car running the head lights on try t ...
John_Muha
PostForum: Electrical Systems   Posted: Fri Feb 18, 2005 12:22 pm   Subject: HEADLIGHT WORK WHEN THEY WANT TO
I'd connect a test meter (VOM) to the BAT terminal on the fuseblock. There should be 12 volts at all times. See if it disappears as you honk the horn or open the door.
  Topic: Girls and el caminos
John_Muha
PostForum: General BS Topics   Posted: Wed Feb 16, 2005 10:33 am   Subject: Girls and el caminos
I don't have an El Camino. It's the wife's car. She wanted it and went out to buy it dragging me along.
Page 1 of 15 Goto page 1, 2, 3 ... 13, 14, 15  Next
