El Camino Central :: Search
Search found 26 matches
El Camino Central Forum Index
  Topic: FI options for a 99 Vortec
Pyromanaron
PostForum: LT1/LS1/EFI Tech   Posted: Wed Jul 09, 2008 10:41 pm   Subject: FI options for a 99 Vortec
The only Edelbrock EFI set up I know of is their "Pro-Flo". I plan on using that.
  Topic: very strange, need help
Pyromanaron
PostForum: Engine Topics   Posted: Wed Jul 09, 2008 10:34 pm   Subject: very strange, need help
Its not really new, I've been playing with it off and on, had a huge problem that turned out to be the power valve. I think it has a thin gasket. It also runs rough when I keep the throttle down, so ...
Pyromanaron
PostForum: Engine Topics   Posted: Wed Jul 09, 2008 4:30 pm   Subject: very strange, need help
I have an 85 caballero with a 305. I put a holley carb and vacuum advance distributor on it. I have to hold the gas pedal to the floor for it to crank up, and as soon as I take my foot off the gas c ...
  Topic: Why would anyone want the a "new" Elco
Pyromanaron
PostForum: General BS Topics   Posted: Thu Nov 15, 2007 4:13 pm   Subject: Why would anyone want the a "new" Elco
How about the drivetrain from a Ute in an old-skool elco? With lots and lots of NITROUS!!!!!!!!!! And when it blows up, you can put the old stuff back in.
  Topic: Cool Song
Pyromanaron
PostForum: General BS Topics   Posted: Thu Nov 15, 2007 4:06 pm   Subject: Cool Song
I watched it twice
  Topic: Can't get my 85 timed
Pyromanaron
PostForum: Ignition Upgrades & Discussion Forum   Posted: Sat Sep 08, 2007 9:33 pm   Subject: Can't get my 85 timed
I got a vacuum advance distributor! I'll get it cleaned up and try to get it put in tommorrow.
Pyromanaron
PostForum: Ignition Upgrades & Discussion Forum   Posted: Fri Sep 07, 2007 10:17 pm   Subject: Can't get my 85 timed
South Alabama, north Baldwin county. Its God's oven. How about you guys?
  Topic: Dodge Rampage
Pyromanaron
PostForum: General BS Topics   Posted: Fri Sep 07, 2007 10:10 pm   Subject: Dodge Rampage
I was thinking of making the Rampage my daily in-town runner while I got my Dodge Ram turned into a beast. A 440 powered beast.
Pyromanaron
PostForum: General BS Topics   Posted: Fri Sep 07, 2007 1:45 pm   Subject: Dodge Rampage
There is an untouched Dodge Rampage in my neighborhood. If I ever get a chance, I'm gonna try to buy it. Opinions?
  Topic: Anyone might happen to know?
Pyromanaron
PostForum: Audio   Posted: Fri Sep 07, 2007 1:38 pm   Subject: Anyone might happen to know?
What custom job?
Pyromanaron
PostForum: Ignition Upgrades & Discussion Forum   Posted: Fri Sep 07, 2007 1:34 pm   Subject: Can't get my 85 timed
Well, crap. Will the new distributor fit a big block? The only reason I put the new stuff on was because I basically got it for free. I want to spend as little money on the 305, so I can build up a ...
  Topic: Lessons Learned from a motor swap
Pyromanaron
PostForum: Performance Modifications   Posted: Thu Sep 06, 2007 10:27 pm   Subject: Lessons Learned from a motor swap
Holy Crap! You sniped a van with your pulley?
  Topic: Possible Upgrade Question
Pyromanaron
PostForum: Performance Modifications   Posted: Thu Sep 06, 2007 10:22 pm   Subject: Possible Upgrade Question
How about reworked factory heads from a 305 or a 327? The 327 might be hard to find, but the 305 heads might raise your compression too much for pump gas. Or you can get the 350 heads ported, polish ...
Pyromanaron
PostForum: Ignition Upgrades & Discussion Forum   Posted: Thu Sep 06, 2007 10:01 pm   Subject: Can't get my 85 timed
Stock HEI distributor, and it was at TDC on the compression stroke. It cranked and ran at 8 degrees advance, but I couldn't get it to adjust in any possible way. I didn't have access to a timing lig ...
  Topic: T-56 into Caballero
Pyromanaron
PostForum: Transmission & Drive line   Posted: Thu Sep 06, 2007 1:47 pm   Subject: T-56 into Caballero
What is necessary to get the T-56 into a 85 Caballero that came with a TH200?
Page 1 of 2 Goto page 1, 2  Next
