I noticed when I logged on tonight there were 14 members and 99 visitors. Anybody have any statistics on the visitors? Just curious who they are and what they do on the site?
OK, I'm in. Nitrogen is used in aircraft tires because nitrogen molecules are larger that oxygen molecules, therefore less leakage due to pressure and temperature influences of flight. BTW, the eart ...
I had the same OEM and I purchased the same replacement EGR141. Without pulling the valve to confirm which washer I used, I can tell you the ones I had left over (flat washers: 56, 50, 47 ...
Tell us more about the EGR valve. The wrong sized EGR will give you exactly the hesitation system you described. The EGR is switched out until after the engine warms up.
Sorry guys, no time to search. I know the ECM controls the lockup of the transmissions torque converter. And that this should happen in 3rd or 4th gear around/above 40 MPH ...
