Phoenix
El Camino Central :: Search
Search found 87 matches
El Camino Central Forum Index
  Topic: Stripped sway-bar bushing bolt/hole
hawaii1984
PostForum: Suspension   Posted: Wed Oct 15, 2008 1:03 pm   Subject: Re: Stripped sway-bar bushing bolt/hole
[/quote]I think you answered your own question.[/quote]
I was afraid of that Confused
hawaii1984
hawaii1984
PostForum: Suspension   Posted: Wed Oct 15, 2008 12:17 pm   Subject: Can't fit fingers..
Unfortunately I can't fit my fingers in there to thread a nut on. Do I have any other options?
  Topic: End link nuts won't start. Threads hiding in bush
hawaii1984
PostForum: Suspension   Posted: Wed Oct 15, 2008 12:06 pm   Subject: short bolt
I mocked up the end link off the car and the threads only go 1/2 way through the nut. I should've saw this before. Thanks for the tip Tom. Gonna see if they have another set at redline and if not, the ...
hawaii1984
PostForum: Suspension   Posted: Tue Oct 14, 2008 4:33 pm   Subject: End link nuts won't start. Threads hiding in bush
Can't seem to get the bushings on a new set of end links to compress enough to get the nut started. Should the car be jacked with the tires suspended or should the car be up on ramps for this repair? ...
hawaii1984
PostForum: Suspension   Posted: Tue Oct 14, 2008 4:24 pm   Subject: Stripped sway-bar bushing bolt/hole
I have one sway-bar bushing bolt that has a stripped hole. What's the size of the stock bolt and anyone have a fix/solution for this dilemma. I'm assuming a tap & dye set is in my near future.... ...
  Topic: Gas tank sending unit and capacity
hawaii1984
PostForum: Engine Topics   Posted: Sat Oct 11, 2008 12:08 am   Subject: Wrong sending unit!!!
Mad Yes that's a good price...if it were the right part!
The tabs didn't line up unless I rotated the sending unit 180 degrees which would point the fuel line in the wrong direction...backwards..
So ...
  Topic: Cleaning my old '84 gas tank b4 installation
hawaii1984
PostForum: Engine Topics   Posted: Thu Oct 09, 2008 3:32 pm   Subject: Cleaning my old '84 gas tank b4 installation
Want to see if I should do any cleaning or prep before I re-install the gas tank on my '84.
The top of the tank is pretty crusty. Should I clean and por-15 it or??
The outside of the tank of cours ...
  Topic: Dye for headliner
hawaii1984
PostForum: Interior Restoration   Posted: Tue Oct 07, 2008 1:43 pm   Subject: Dye for headliner
The headliner in my '84 is in really good condition, but it's a tan color and I want it to be black. Is there a fabric dye I can spray on or is the vinyl dye what I should use? I'm ordering the carpet ...
hawaii1984
PostForum: Engine Topics   Posted: Tue Oct 07, 2008 3:26 am   Subject: Sending unit ordered
Thanks for all your help. E-bay was a dead end and opg's part @ about $180 was on back order for the next 4 weeks. Summit did some digging and found one in stock for $99. It'll be here in a couple day ...
hawaii1984
PostForum: Engine Topics   Posted: Sat Oct 04, 2008 6:27 pm   Subject: Unit size
So I'll be looking for a sending unit for a 17 gal tank..
Thanks!!
I'll try e-bay since everyone is closed today..
hawaii1984
PostForum: Engine Topics   Posted: Sat Oct 04, 2008 4:05 pm   Subject: w/ 22 gal
Yea, that's how it looks to me too, but it would sure be simpler if they just said what it is and not what it isn't.. Confused
Got to read between the lines I guess..
87ElCamino, you appear to have hit t ...
hawaii1984
PostForum: Engine Topics   Posted: Sat Oct 04, 2008 1:49 pm   Subject: Tank capacity
http://www.gmpartcatalog.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214551
I hope you can open this link.
If not, type in the p/n below and select chevrolet/geo.
Part #14091336 ...
hawaii1984
PostForum: Engine Topics   Posted: Fri Oct 03, 2008 11:28 pm   Subject: Gas tank sending unit and capacity
I just pulled the tank on my '84 Elk.
How do I tell the gallon capacity?
Someone once mentioned if the sending unit is working, re-use it.
My gauge at full reads between half and 3/4 tank so I neve ...
  Topic: Fuel Tank sending unit? I need one..
hawaii1984
PostForum: Engine Topics   Posted: Tue Sep 23, 2008 4:26 am   Subject: Fuel Tank sending unit? I need one..
Where can I look for a new sending unit for my '84 Elky.
I need to get it asap. Unless anyone thinks it'd be ok to re-use the old one and just replace the seal and fuel lines..
Any thoughts or recom ...
Page 1 of 6 Goto page 1, 2, 3, 4, 5, 6  Next
Page Generation: 0.576 Seconds
