Phoenix
El Camino Central :: Search
Search found 107 matches
El Camino Central Forum Index
  Topic: Water and Oil sender
hel98
PostForum: Engine Topics   Posted: Sat Aug 23, 2008 5:57 pm   Subject: Water and Oil sender
Thanks. PM ahead.
hel98
PostForum: Engine Topics   Posted: Sat Aug 23, 2008 4:47 pm   Subject: Water and Oil sender
There's an oil port on the rear of the block to the left of the distributor. It's 1/8 npt. You'll probably need a four or eight point socket to get it out without rounding it off.You can also use a br ...
  Topic: Fuel Filter
hel98
PostForum: Engine Topics   Posted: Tue Aug 19, 2008 8:41 pm   Subject: Fuel Filter
Buy a cheap 1" combo wrench and cut a slot just large enough to fit over the fuel line. You'll need a 5/8 line wrench for the small nut. Hold the large nut so it won't turn and use the hex end of the ...
  Topic: Bumping noise in bed.
hel98
PostForum: Suspension   Posted: Wed Jul 09, 2008 4:17 pm   Subject: Bumping noise in bed.
Could be the coils are binding. It's more noticeable with variable rate springs. GM had a service bulletin in the mid 80s for a thumping noise in the rear of G and B cars. The fix was to index the spr ...
  Topic: 5th gen PST/Addco rear sway bar question
hel98
PostForum: Suspension   Posted: Sat Jun 28, 2008 1:53 pm   Subject: 5th gen PST/Addco rear sway bar question
Yeah, the possums and ground hogs will go under. Ya better dodge the deer, tho.http://i256.photobucket.com/albums/hh185/hel98/S4010270.jpg
Nothing wrong with free parts. You saved a c note on that ba ...
  Topic: computer problems still
hel98
PostForum: Electrical Systems   Posted: Thu Jun 05, 2008 2:21 pm   Subject: computer problems still
The lamp driver module may be shorted. Should be a small green plastic box located above or to the right of the glove box, tied to the harness. The ecm controls this to turn on the ck. eng. light. Wit ...
  Topic: 67 Elko will Start while in the start position but then dies
hel98
PostForum: Electrical Systems   Posted: Thu May 22, 2008 8:43 pm   Subject: 67 Elko will Start while in the start position but then dies
There should be 2 wires on the + side of the coil. One runs from the R terminal on the starter. It supplies full battery voltage to the coil when cranking.
The second wire is a resistor that drops th ...
hel98
PostForum: Suspension   Posted: Fri May 16, 2008 10:05 pm   Subject: 5th gen PST/Addco rear sway bar question
Heres what you need.http://i256.photobucket.com/albums/hh185/hel98/swaybarmounts.jpg
  Topic: No sound from CD player or radio
hel98
PostForum: Electrical Systems   Posted: Fri May 16, 2008 7:11 pm   Subject: No sound from CD player or radio
Mike,if the problem isn't in the head unit itself it's possible the speaker wires are shorting to the body or together. Could be causing the amp in the head to shut down. Turning it off and on resets ...
  Topic: `69 Elky W/`90-`92 TPI Needs Ether For Cold Start
hel98
PostForum: LT1/LS1/EFI Tech   Posted: Sat May 10, 2008 10:10 pm   Subject: `69 Elky W/`90-`92 TPI Needs Ether For Cold Start
Are you waiting 10-15 seconds between cycles? The ECM won't activate the pump after the first time without the interval.
Possible the coolant temp sensor is not reading correctly, but not out of wh ...
  Topic: Purple Wire 4 TCC, How does the Factory Hook Up W/Cruise
hel98
PostForum: Electrical Systems   Posted: Tue May 06, 2008 3:43 pm   Subject: Purple Wire 4 TCC, How does the Factory Hook Up W/Cruise
The converter and brake functions are on one switch.http://i256.photobucket.com/albums/hh185/hel98/brakeswitch.jpg
The connector on the end is for the conv. Should be pink/black stripe and purple. ...
  Topic: tpi setup
hel98
PostForum: Garage Sales   Posted: Thu May 01, 2008 1:09 pm   Subject: tpi setup
Yeah, I still have it. The extra set of injectors are not Accel. They're the stock ones from the intake I used on my El.
I also have a new Painless MAF harness with another 165 ECM and an extra MAF ...
  Topic: scat/procar...any experience?
hel98
PostForum: Interior Restoration   Posted: Mon Apr 14, 2008 8:19 pm   Subject: scat/procar...any experience?
Max, you have the split bench so mounting the seats will be a lot easier. The inner mounts are already there.You could probably just use a piece of plate steel or aluminum and some spacers drilled to ...
  Topic: Fuel sending unit?
hel98
PostForum: Engine Topics   Posted: Mon Apr 14, 2008 5:41 pm   Subject: Fuel sending unit?
Mike , if the tank on your 83 is the same as my 82 it has an angled dome that the sender mounts on. The one you're looking at is for a flat top tank.It may fit the tank if you mod the locating tabs, b ...
  Topic: New Chevelle Concept Car 454 (real car)
hel98
PostForum: General BS Topics   Posted: Fri Apr 11, 2008 5:53 pm   Subject: New Chevelle Concept Car 454 (real car)
I like it, too. Looks like 2nd generation Chevelle and late Monte Carlo combination. GM shoulda put that mill in the SSR. Probably would have sold a lot more of em. It would make a nice platform for t ...
Page 1 of 8 Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
Page Generation: 1.015 Seconds
