Posted: Sun Apr 06, 2008 10:01 pm Post subject: My Elky needs to go on a diet...
This heavy pig needs to lose some weight, does anyone know any little tricks to dumpin some excess weight without doing a sheet metal car? Any help would be appreciated...
Thanks,
C.J. _________________ I know what you're thinking, why not a Corvette? Why not a GT40? Well my friends those are just cars, El Camino is a way of life...
Sometimes it is better served to add HP as opposed to losing weight on a street driven vehicle. Mainly for safety issues! As for losing the back bumper to shed weight, that would be counter productive due to traction issues. _________________ "Still Just Truck'in"
"Johnny"
Bradley, Illinois
As far as fiberglass hood is concerned, from personmal experience I'd say don't bother. Unless you're racing the fiberglass hood is more torible than it's worth. If you get real lucky and get one that's straight and fits well it still will never fit perfectly and can't be treeked to fit. If you want a good fit and want it to look right then stick with metal, the cost is the same. _________________ Leo
1986 El Camino
1997 Lincoln Mark VIII LSC
Earl Hickey
Hey thanks guys, I appreciate it. I would like to add some more power, but I'm on a High School Budget. Thanks for the tips though, Seems like I could find some of that stuff for pretty cheap, I was plannin of givin up the A/C Cause it's broken anyways, plus I have to ditch the hitch (sure that's not helping with weight ) Do you think I could swap in some seats out of an 87 Camaro easily?
Thanks alot,
Sweet! Thanks man! Junkyard time... _________________ I know what you're thinking, why not a Corvette? Why not a GT40? Well my friends those are just cars, El Camino is a way of life...
Posted: Thu Apr 10, 2008 10:19 pm Post subject:
If your cruck has 60/40 or buckets you can use factory brackets as mentioned earlier.
if you have a full bench you will need to weld in the inner floor brackets from a donor car, because GM, in their infinite foresight left those out on bench equipped vehicles. _________________
Ok, I know this is gonna sound dumb, but ...
By 60/40 do you mean this?
If so, I think I have the full bench. Sorry, I'm still learnin' _________________ I know what you're thinking, why not a Corvette? Why not a GT40? Well my friends those are just cars, El Camino is a way of life...
Posted: Fri Apr 11, 2008 5:43 pm Post subject:
Look under the seat. If its a 60/40 you'll have two sliders on each side of the seat. If its a standard beanch it will only have one slider on each side of the seat.
Cool thanks!
This weekend I finally got some tome with my car so I ditched the A/C, Hitch, hit the swap meet and got some headers, and a pair of 10" wide cragar SS wheels with Drag slicks for 25$ so I'm real excited now! _________________ I know what you're thinking, why not a Corvette? Why not a GT40? Well my friends those are just cars, El Camino is a way of life...
Necoa #: 12660
Posted: Sat Oct 18, 2008 9:08 pm Post subject: How do i remove my AC?
On this 83 the Ac doesn't work so i was considering removing what i could to free up space.
Any tips would help, also would taking the compressor off affect my timing belt?
Posted: Sat Oct 18, 2008 11:46 pm Post subject:
You live in Texas and you want to remove your air conditioning? Why don't you get it going again? Anyway your Elky does not have a timing belt. The A/C compressor belt also helps drive the power steering pump but the pump also has another belt running it so probably no issues in removing the A/C compressor belt.
Necoa #: 12660
Posted: Mon Oct 20, 2008 3:13 pm Post subject:
I discovered that If you take the AC belt off then the fan and alternator pulleys wont spin. (AC shares the fan pulley)
So i need a belt that will bypass the AC pulley and go to the power steering pump instead..
In other words a belt that goes from the crank pulley to the fan pulley to the power steering pulley..
Anyone know what size that belt would be..
I could measure if i have to...
Posted: Mon Oct 20, 2008 4:03 pm Post subject:
I think you need to take another look. On my '85 there is a belt from the crank pulley that drives the water pump pulley with the fan and the alternator. The power steering is driven by a belt from the crank pulley and augmented by the A/C compressor belt.
So at least my case the fan/water pump and alternator is powered from a belt from the crank pulley. And another belt from the crank only to the power steering pump. Then there is a belt from the fan pulley to the air (smog) pump. I would think the '83 would be the same.
