Phoenix
El Camino Central :: View topic - 95 Camaro rear end swap into 86 El Camino?
Ebbsspeed
Necoa #: 5984
PostPosted: Sun Jul 08, 2007 7:44 pm    Post subject: 95 Camaro rear end swap into 86 El Camino? Reply with quote
A guy offered me a posi rear from a 95 Camaro, any info on whether it's a bolt-in deal, or what is required to do it? Also, did the 95 Camaro's have an 8.5 inch rear, or is it basically the same 7.5 incher that the El Camino has in it stock? The rear disk brakes are attractive......
Thanks!
Poltergeist
Gallery Administrator
Necoa #: 478
PostPosted: Sun Jul 08, 2007 8:04 pm    Post subject: Reply with quote
The rear end is a 7.5. And it is NOT a bolt in deal, that year Camaro uses a panhard bar to keep the rear centered and not a 4 link like the Elkies.
You can modify your rearend to accept the backing plates and brakes though if you want.
This for a 3rd gen Camaro but the idea is the same for the El Camino. This is what I did to put 2001 Camaro brakes on my 82. http://www.thirdgen.org/ls1reardisc Or look at this thread http://www.thirdgen.org/techboard/brake-board/423270-hassle-free-drum-rear.html This guy now sells brackets that will work with LT1 brakes and you do not have to cut up the rearend.
ECC Member #002
PostPosted: Tue Feb 19, 2008 9:43 pm    Post subject: Reply with quote
BIZ-UMP!
Poltergeist, what does PBR refer to when talking about f-body brakes?
would it be possible to use the backing plate in that link but instead of lt1 calipers and discs, use say.... LS1 or C5, C6 rotors and calipers?
I want rear discs bad, but the last thing I want to do is take a sawzall to my GN rear.
Poltergeist
Necoa #: 478
PostPosted: Tue Feb 19, 2008 11:24 pm    Post subject: Reply with quote
You would need to use a backing plate from an LS1 rear to use LS1 rear calipers. Same for a C5 setup. But there is now this option that is almost ready:
http://www.thirdgen.org/techboard/brake-board/441658-drum-rear-c5-c6.html
take look at that thread. One thing with using that bracket is there is no way to have an emergency brake. I still need to do some more work to get my emergency brake hooked up. The person doing the bracket is who I got the adapters for my front C5 setup. Here is my setup.
http://www.poltergeist.us/page/Elky/ElKy_pictures_brakes.htm
On that page click on the 'Rearend modifications' link down towards the bottom to see what I did and how it came out.
PBR is the manufacture of the calipers, pbr.com. You can't buy direct from them.
If you are talking about the base C6 brakes then the bolt pattern is same as the C5s and are a direct swap. The C6 Z06 could be done also but I think you need at least a 19" wheel in the front to clear the 6 piston caliper. Personally I think the base C6, C5 or LS1 should do anyone just fine. The C6 Z06 is overkill, but that is just my feeling.
ECC Member #002
PostPosted: Wed Feb 20, 2008 9:40 pm    Post subject: Reply with quote
So are all 93-97 f-bodies PBR brakes?
the ebrake on PBR is in the caliper correct?
didn't you have to relocate the shocks to make your LS1 rears work?
I'm trying to come up with a complete bolt-on design using mostly production parts. I've already discovered that late-model Blazer spindles use a rotor-over-hub design eliminating the need to machine down my rotors.
Poltergeist
Necoa #: 478
PostPosted: Wed Feb 20, 2008 10:15 pm    Post subject: Reply with quote
PBRs have been used on GMs since I think the 80s. All 93-2008 GM calipers are PBR that I'm aware of. The E-brake on the 93-97 LT1 Camaro's is on the caliper, the 98-02 LS1 brakes have the E-brake in the hub of the rotor.
Yes I had to relocate the shock to clear the caliper but you would also have to for the LT1 setup. More so because of the lever for the E-brake.
The problem you're going to have with the S-10 spindles is that the bearings for the hubs are no longer made and I don't think anyone has started to make them since I looked at them a while back.
ECC Member #002
PostPosted: Fri Feb 29, 2008 11:33 pm    Post subject: Reply with quote
PBR brakes came out in 89 in the F-bodies. The earlier disk brakes were Morane cast iron calipers. Not real popular when they were new. The PBR's are aluminum and pretty much the same entry level rear disc kit Baer sells. You can get the backing plate from EBMiller in the hassle free link above. Me makes them for both the 7.5 and 8.5 rear ends. And, the posi unit will be 28 spline where the G-body axles are 26 spline.
PostPosted: Sat Mar 01, 2008 1:25 pm    Post subject: Reply with quote
in that hassle free link, can I get the backing plates from an 89-97 f-body with PBR or 1LE rear discs?
or are those plates something that are custom fabricated by Ed. I don't see why I couldn't just use factory parts from a junkyard as far as the plates.
don't Camaro's from 82-97 have the same "rectangular" flanges as us? and then went to the square flanges in 98 with the new brakes?
PostPosted: Sat Mar 01, 2008 2:06 pm    Post subject: Reply with quote
The backing plates are fabbed by Ed. He may or may not have fortory stuff. Yes you could use factory stuff from a junk yard if you can find it. Not sure if it would need any shimming to line up with the G-body axles or not. Not sure about what year had what flanges on the rears. I have a set of Ed's backing plates. Just have not had a chance to install them yet.
PostPosted: Sat Mar 01, 2008 9:50 pm    Post subject: Reply with quote
so tom, you are doing the LT1 style brakes? or are the vrackests you have for LS1?
PostPosted: Sat Mar 01, 2008 11:55 pm    Post subject: Reply with quote
I have the third gen F-body PBR rear brakes I'm working on.
PostPosted: Sat Mar 15, 2008 11:44 pm    Post subject: Reply with quote
I just accidently ran across a picture of a monte carlo with these brakes. the shocks appeared to be relocated, but it wasn't a good shot. the focus was on the differential.
so will I have to relocate my shocks? PBR caliper do look really big.
PostPosted: Sun Mar 16, 2008 12:52 am    Post subject: Reply with quote
If the shocks need to be relocated, its the first I've heard of it. Have not read this on either the G-body or f-body forums.
oldelky80
Necoa #: 5347
PostPosted: Sun Mar 16, 2008 8:16 am    Post subject: Reply with quote
The lower shock mount needs to be move inward to clear the emergency brake bracket. A simple L bracket is all that is needed.
PostPosted: Sun Mar 16, 2008 10:18 am    Post subject: Reply with quote
is that the exact setup? what had to be done to the breke lines? and what about the ebrake?
Page Generation: 0.920 Seconds
