El Camino Central :: View topic - Window Sweeps Removal
PostPosted: Sun Sep 30, 2007 10:40 am    Post subject: Window Sweeps Removal Reply with quote
greywolf
Necoa #: 64
PostPosted: Fri Oct 19, 2007 9:20 pm    Post subject: Reply with quote
PostPosted: Sat Oct 20, 2007 9:01 am    Post subject: Reply with quote
I think you got lucky greywolf. It seems most door glass does not get low enough without removing the down-travel stop to access the screws. I know mine did not and that was with the interior panel removed.....Doug
Caballero78
Necoa #: 8262
PostPosted: Sat Oct 27, 2007 7:23 am    Post subject: Thanks Reply with quote
I need to do this also, alot of the books I have arent detailed are understandable to me lol, but reading how to do things from how others do is a great help thanks
VROOM VROOM lets ride!!!!
PostPosted: Tue Apr 15, 2008 11:30 pm    Post subject: Reply with quote
I had to remove the glass in my '81. I had the window out while painting anyway, so it wasn't as big a deal for me. Taking the window out wasn't as bad as I thought it would be, I left the regulator in to avoid any more work than was necessary.
My "Hell Camino" Homepage
"Attitude is everything"
Twilight Fenrir
Necoa #: 11447
PostPosted: Tue Apr 15, 2008 11:50 pm    Post subject: Reply with quote
On my driver door, I managed to finagle a screwdriver in there just by removing the inner felts and such... but the passenger was a different story, I wound up breaking off the ends of the felt, and just spinning it arround inside the door, thankfully it gripped the screw long enough for me to hack-saw it off.... I just didn't install the middle one again Poke Tounge
ACZ66
Necoa #: 9679
Year: 1966
PostPosted: Fri May 16, 2008 3:13 pm    Post subject: Reply with quote
mca_daddy
Necoa #: 11478
PostPosted: Fri May 23, 2008 11:12 am    Post subject: Reply with quote
Any ideas where to get good replacement weatherstrips for an 85?
PostPosted: Fri May 23, 2008 10:04 pm    Post subject: Reply with quote
I got mine from Mikes Montes. The roof rail wheather strips are not equal to originals but neither is anyone elses. Link,
http://mikesmontes.com/proddetail.asp?prod=319&cat=2892
Page Generation: 0.612 Seconds
