El Camino Central :: View topic - More a/c drama
More a/c drama
El_Ron84
Necoa #: 9663
PostPosted: Sun May 11, 2008 2:06 pm    Post subject: More a/c drama Reply with quote
Thanks,
Ron
PostPosted: Sun May 11, 2008 2:41 pm    Post subject: Reply with quote
Your not getting any voltage to the compressor clutch to kick it in. Make sure it is plugged in at the compressor as well as the low pressure cutoff switch over by the receiver drier.
El_Ron84
Necoa #: 9663
PostPosted: Sun May 11, 2008 4:39 pm    Post subject: More a/c drama Reply with quote
El_Ron84
Necoa #: 9663
PostPosted: Sun May 11, 2008 5:36 pm    Post subject: More a/c drama Reply with quote
Thanks so Much,
Ron
PostPosted: Sun May 11, 2008 5:46 pm    Post subject: Reply with quote
Glad I could get you going in the right direction. If the compressor wasn't kicking on when you were charging the system you probably just need to top it off. What low side pressure are you running now? Needs to be about 30.
El_Ron84
Necoa #: 9663
PostPosted: Mon May 12, 2008 8:35 pm    Post subject: More a/c drama Reply with quote
Ron
mhamilton
Necoa #: 6495
El_Ron84
Necoa #: 9663
PostPosted: Fri May 16, 2008 8:59 pm    Post subject: More a/c drama Reply with quote
Yes it is retro'd to R-134. I will take your advice and make the screw adjustment. I will keep you posted.
Thanks,
Ron
El_Ron84
Necoa #: 9663
PostPosted: Sat May 17, 2008 4:16 pm    Post subject: More a/c drama Reply with quote
Thanks,
Ron
mhamilton
Necoa #: 6495
PostPosted: Sun May 18, 2008 10:39 am    Post subject: Reply with quote
Great news!
Page Generation: 1.235 Seconds
