El Camino Central :: View topic - Converter Lock-up kit
hawaii1984
Necoa #: 11592
PostPosted: Fri May 16, 2008 2:05 pm    Post subject: Converter Lock-up kit Reply with quote
I am planning on pulling a 2004r from a '87 Monte for my '84 Elk and understand there is a mod (converter lock-up kit) that I need to perform.
I looked up BTO and saw different options so if someone could share their experience with me and the easiest & most effective route as far as what kit and how to...
I would appreciate it!
Aloha,
Scott
hawaii1984
Necoa #: 11592
PostPosted: Sun May 18, 2008 1:56 am    Post subject: Anyone?? Reply with quote
I also have a 7004r, but either way, I need more info on the lock up kit!
Which tranny would be the best chooice? friends here are telling me the 2004r is the one.
Anyone?
PostPosted: Sun May 18, 2008 10:26 am    Post subject: Reply with quote
If you use all the parts from the Monte, the 2004R should bolt in. If you go with the 700R4 it will be a bit more work. Which one is in better shape? It's not cheap to get an OD tranny rebuilt. As for lock up kits, there are several available. Some use a simple electrical signal, others use engine vacuum to send the signal. You can search on Jeg's or Summit for different makes. You can also wire it your self with a toggle switch on the dash. But if you forget to unlock the convertor the car will stall when you come to a stop.
eliselky383
Necoa #: 10087
PostPosted: Mon May 19, 2008 8:31 pm    Post subject: Reply with quote
ck out bowtieoverdrive.com good info and parts for both tranny's
it's mine it's paid for and i'll smoke them if i want to
Page Generation: 0.504 Seconds
