El Camino Central :: View topic - not starting
not starting
44oldelcamino
Necoa #: 9069
PostPosted: Sun May 18, 2008 3:49 pm    Post subject: not starting Reply with quote
70 el camino 350
the battery turned the starter very weak , at the beginning of problem.
turn the key-not even a click.
the car starts on jump!
the problem now , is no power , just dead!
12 volts at new battery , 12 volts new alternator.
checked the solenoid, 12 volts at both points.
lights work,just no power to the starter???
what else could be causing this???
please answer, with many possibilities.
so i can check .
awest
Necoa #: 10900
PostPosted: Sun May 18, 2008 4:25 pm    Post subject: Reply with quote
Battery or wire connections and/or starter solenoid.
44oldelcamino
Necoa #: 9069
PostPosted: Sun May 18, 2008 5:06 pm    Post subject: not starting Reply with quote
battery is new. 12 volts
could the cables be bad?
ive checked the ground at the engine. getting 12 volts.
checked the frame ground off the battery. 12 volts
solenoid is good.
problem is not getting any power to even turn he starter.
checked the wires for heat stroke, getting 12 volts off th solenoid and the wires.
if someone can please help, id appreciate it.
PostPosted: Sun May 18, 2008 6:26 pm    Post subject: Reply with quote
First thoughts. Since it will start when you jump it - kind of points toward a bad connection on the posts or even a bad new battery. that is the only two things you are eliminating when jumping.
44oldelcamino
Necoa #: 9069
PostPosted: Sun May 18, 2008 9:47 pm    Post subject: not starting Reply with quote
problem resolved
new battery
Page Generation: 0.296 Seconds
