El Camino Central :: View topic - Torque conveerter lockup question.
Goto page Previous  1, 2
bigdave396
Necoa #: 11320
PostPosted: Thu Apr 10, 2008 10:21 am    Post subject: Reply with quote
true that could also cause the same things as could a faulty brake switch
bigdave396
Necoa #: 11320
PostPosted: Thu Apr 10, 2008 10:22 am    Post subject: Reply with quote
mnunn
Necoa #: 5673
PostPosted: Fri Apr 11, 2008 5:07 pm    Post subject: Reply with quote
spoonplugger wrote:
This response is a little late, but better than never. Right? I had the same problem and found the problem was a faulty Throttle position Sensor (TPS). Apparently, the rheostat had a bad spot in the coil. The TPS is located in the electronic carburetor. About $26.00 from Auto Zone, if memory serves me correctly. Before you replace it, be sure you know how to adjst the voltage and make sure you have the adjsuting tool in hand, otherwise, it's a pain in the butt.
Mee too, EXACTLY!
I had an 87 Olds V6., Metric 200C tranny. Rebuilt the carb and didn't adjust the TPS correctly. It would go into overdrive when passing and run around unlocked when at a constant speed. Mad
Once I adjusted the TPS correctly the problem went away completely.
(Technospeek: My computer wouldn't read TPS voltages below 1.0 volts and because of the poorly adjusted TPS, that wasn't occuring until 1/2 throttle or above in my case)
One other point.
When I explained the behavior to the tranny guy we went for a ride above 40 MPH. Then he mashed on the gas to engage the TCC lockup. He then lightly tapped the brakes and because that unlocked it, he was able to rule out the computer and the tranny/torque converter as the problem.
Try cruising as usual, and then when you see the RPMs drop and you know the TCC's locked up, just tap the brakes and see if it unlocks. If it does it's most likely not the tranny or the computer and is more likely the TPS adjustment (or related computer input signal) as it was in my case.
Good luck.
29 Model A (Recently Sold).
PostPosted: Fri Apr 11, 2008 6:06 pm    Post subject: Reply with quote
Isn't 300-400 RPM a lot for a lock up convertor? I know my 700R4 only drops about 50 RPM when it locks up. Maybe the older stuff was a bit different but I didn't think the convertor had that much slippage in it.
Page 2 of 2
