El Camino Central :: View topic - where in the world is the specs sticker to find gear ratio
hddave1
Necoa #: 10958
PostPosted: Sun Mar 16, 2008 12:29 pm    Post subject: where in the world is the specs sticker to find gear ratio Reply with quote
where do i look to find what rear end gear ratio..i've looked in glove box and behind the seat and cant find a specs sticker...can some one tell where to look..its a 85 elky...thanks
1985 el camino 350 sbc crate th350 trans with shift kit
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sun Mar 16, 2008 12:47 pm    Post subject: Reply with quote
Code will be stamped on front side of axle tube, passenger side. Post code and we can tell you what you have. Secondly you can count number of teeth on your ring divided by number of teeth on your pinion to give you your ratio.
PostPosted: Sun Mar 16, 2008 12:51 pm    Post subject: Reply with quote
If you don't have an options sticker inside the glove box you can crawl underneath the rear axle and get the code from the axle tube. Read this thread.
http://elcaminocentral.com/ftopict-11474.html
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sun Mar 16, 2008 12:53 pm    Post subject: Reply with quote
Isn't that what I said? Banghead
K5Cruiser
Necoa #: 6708
PostPosted: Sun Mar 16, 2008 1:06 pm    Post subject: Reply with quote
Here's another option for you to figure out what gear ratio you have. I had posted this on another site that is primarily truck based, so the gear ratio number examples are a little higher (numerically). This also helps because the code on the axle may not necessarily match the rear end gears if a gear swap was done some time in the past.
If you don't want to pull the cover and end up having to put in new gear oil, do the following:
- Jack up the rear end so the tires are not touching the ground and place some jackstands under the rear axle housing, make sure the front wheels are blocked / chocked before you jack it up.
- Release the parking brake and place the transmission in neutral.
- Mark the driveshaft with some of your wife's favorite nail polish, or some tape will work also.
- Now rotate the rear tire by hand one full 360 degree turn. While doing that count the number of times the mark on the driveshaft turns around.
If you count 3 and 3/4 turns, you probably have 3.73 gears. If you count just over 4 turns, you probably have 4.10 gears. I'm sure you get the idea by now.
hddave1
Necoa #: 10958
PostPosted: Sun Mar 16, 2008 8:08 pm    Post subject: Reply with quote
well i crawled under car and looked but didnt see any number so im going to get a wire brush try cleaning it up to see...if not i'll raise the car and count the drive shaft turns.. im wanting to see what i have so i can determin what lower gear im going to get to help my new 350 move this 3800lbs car without me having to mash the peddle so hard..lol..i was told on another forum that if i had 2.41 ratio i would benafit in a gear change with the 350 setup i have ...
PostPosted: Sun Mar 16, 2008 8:56 pm    Post subject: Reply with quote
Yeah, you have to wire brush the crap out of the axle tube to reveal the codes.
PostPosted: Mon Mar 17, 2008 4:24 am    Post subject: Reply with quote
Yes Hans, but you said it as I was typing my reply so I didn't hear it. Laugh
PostPosted: Mon Mar 17, 2008 4:27 am    Post subject: Reply with quote
hddave1 wrote:
i was told on another forum that if i had 2.41 ratio ..
Most V8 5th gens have either a 2.41 or a 3.08 rear.
GerryP
Necoa #: 11088
PostPosted: Mon Mar 17, 2008 9:50 pm    Post subject: Reply with quote
85 Cab with 305 = 3252 lbs
1971 GMC Sprint (His)
1981 El Camino SS (Hers)
PostPosted: Mon Apr 14, 2008 10:15 am    Post subject: Reply with quote
On my '81 I found the factory build sheet inside the upper door panel. I was told there may be another one above the headliner and/or gas tank. Not sure if an '85 will be the same, but it's a place to start.
