backpressure??
elcamman006
Necoa #: 10766
PostPosted: Wed Apr 09, 2008 11:34 am    Post subject: backpressure?? Reply with quote
does backpressure exsist in a v8 i know it does in the little ricers? but i was thinking of doing cherry bombs or even streight headers with pipes, but my friend brought up the point of back pressure and that i would have no low end if i went strieght out with no crossing, is he correct?
Snaggle To0th
Necoa #: 4293
PostPosted: Wed Apr 09, 2008 10:03 pm    Post subject: Reply with quote
it does but why worry about it? theres no need to unless you use the correct diameter exhaust pipe. that and turbo applications
Proud Wyotech Graduate
elcamman006
Necoa #: 10766
PostPosted: Wed Apr 09, 2008 10:59 pm    Post subject: Reply with quote
so it wont mess up low end? so should i do glass packs or can i go strieght what would have more power
PostPosted: Thu Apr 10, 2008 7:54 am    Post subject: Reply with quote
Set your mind at ease, Glass Packs verses straight both will have the same flow. Glass packs in essence are a straight thru flow that has a side chamber or area that is packed with fiberglass or steel wool type of material. This design is for sound control only, and will not affect the flow to any degree. They will minimise the exhaust "POPS", or backfire "POPS" that can be as they use to say, "ticket bait". They also act somewhat like a spark arrestor. Glass Packs are not a chambered style design of muffler that re-routs the flow, or restricks the flow.
elcamman006
Necoa #: 10766
PostPosted: Thu Apr 10, 2008 10:43 am    Post subject: Reply with quote
got ya thanks. so ill prob go with the glass packs. but no on the cros pipes then?
elcamman006
Necoa #: 10766
PostPosted: Thu Apr 10, 2008 10:44 am    Post subject: Reply with quote
Snaggle To0th
Necoa #: 4293
PostPosted: Fri Apr 11, 2008 11:46 pm    Post subject: Reply with quote
An X-pipe or H-pipe to what you are referring to most likely dont DEAL with backpressure they deal with the actualy FLOW of the exhaust gases and allow them to cross over to one another and project the sound waves to a more crisp sound wave which in return means better flow. WEITHER I got that correct I'm not 100% sure its been a while since i even thought of describing them. I can 100% guarantee this tho! It will give you more horse power and torque. In my opinion glass packs sound like crap, using a 2 chamber muffler such as Flowmaster...Knowing that your from nor cal probably near Sac Town the Flowmaster assembly plant isnt far! They are great mufflers have always used them and you get what you want out of them.
elcamman006
Necoa #: 10766
PostPosted: Sat Apr 12, 2008 4:18 pm    Post subject: Reply with quote
well i think im going to go with stright headers.. but i should cross them and i would get more power than streight back?
conquista90
Necoa #: 7515
PostPosted: Sat Apr 12, 2008 6:01 pm    Post subject: Reply with quote
Stop the text message talk. I have to go back and read every excuse for English that you spew at least 3 times before I can kind of get the concept of what you're trying to convey. Yes, backpressure exists. Why would it be dependent on the number of cylinders?
In my opinion, glasspacks sound like explosive diarrhea. Sure, they flow nice, but so do nowadays mufflers. An X pipe, would be good, but an H pipe would be louder. And I would not advise running straight pipes. It's illegal.
elcamman006
Necoa #: 10766
PostPosted: Sun Apr 13, 2008 3:40 am    Post subject: Reply with quote
im getting so many different answers about the back pressure what flows better x or H
Snaggle To0th
Necoa #: 4293
PostPosted: Mon Apr 14, 2008 1:05 pm    Post subject: Reply with quote
IF IT WERE ME! Id get a X pipe they flow better...Better flow means more power. ya digg? YOU DONT need to worry about back pressure there are more ugly ducklings you need to be worried about. Especially your emissions and if you live in Sac Town you need to worry about Sac Town police. THEY don't joke around.
conquista90
Necoa #: 7515
PostPosted: Mon Apr 14, 2008 4:09 pm    Post subject: Reply with quote
ok like lol wut u wanna do is just go get sum flowmastrs and some stax and just have em stiking out the bak right behnd teh cab. u have 2 cut sum wholes for teh stax, but it would look badass. that wood have zero bakpreshure.
just get a Z pipe and be dun wit it
Snaggle To0th
Necoa #: 4293
PostPosted: Mon Apr 14, 2008 4:47 pm    Post subject: Reply with quote
get a z pipe? give me a BREAK
PostPosted: Mon Apr 14, 2008 10:49 pm    Post subject: Reply with quote
Laughing 4 Laughing 4 Laughing 4 Laughing 4
Okay, That's enough of that.
PostPosted: Tue Apr 15, 2008 1:47 am    Post subject: Reply with quote
