Forged SCAT Stroker Crank with 6" Rods. The Crank fits 350 journals and comes with the 6" H-Beam Rods. The Rods are Summit Racing brand, but are manufactured by Eagle. Everything is new in the box. The crank is for a two piece rear seal application, but an adapter is available from GM if needed for a one piece style.
I bought this crank and rods to build twin turbo engine and then bought a GM Crate engine instead. I would like to sell them still new in the original boxes. It was $1100 for the 4340 Steel Forged Crank and 6" H-beam rods. This is not the cheap kit you see available. This is the good stuff, I'll sell them both for $800.00 Shipped lower 48.
This is the best base to build a 383 Stroker that will live and survive.
