El Camino Central :: View topic - Headers kissing you off as much as me???
Goto page Previous  1, 2, 3  Next
FATRAT96
Necoa #: 812
PostPosted: Sun Oct 10, 2004 8:27 am    Post subject: Reply with quote
i must of got lucky. i bought a set of hooker comps and the only two thing that were in the way were the oil sending unit and the dip stick. it was the eaziest install of all times. and man do they sound great and look even better.
good luck
farat82 john
1982 el camino
2004 ssr
1979 corvette
2004 hate to say ford lightning
ALL BLACK
tuc2001
Necoa #: 6713
PostPosted: Sat Jan 21, 2006 6:46 pm    Post subject: Reply with quote
Are there any headers that fit a '79 with a 350 that will fit more or less problem free, or do the all require jerry-rigging in some way, shape or form?
PaPa Johns 77
Necoa #: 6188
PostPosted: Sat Jan 21, 2006 8:26 pm    Post subject: Reply with quote
Cool Some times you get lucky most of the time you have to do a little tweeking and dinging. Cool Hooker does seem to be the one that needs the least.
"Still Just Truck'in"
"Johnny"
Bradley, Illinois
Mrapii
Necoa #: 2314
PostPosted: Sun Jan 22, 2006 1:23 pm    Post subject: Reply with quote
Hedman Elite headers fit my 1979 with no issues. However they are not full-lenght or equal-lenght which means an easier fit and more ground clearance which was a fair trade-off for me.
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sun Jan 22, 2006 2:13 pm    Post subject: Reply with quote
Put a set of Flo-techs on mine. Had to remove the steering column shifter linkage to fit.
Luvless_69Chevy
Necoa #: 6806
PostPosted: Sun Jan 29, 2006 10:46 pm    Post subject: Reply with quote
Highway69 wrote:
This subject came up before and I think I was the only one who installed Sanderson headers. They've been trouble free and easy to install. Anybody else have them?
http://sandersonheaders.com/
What model did you buy, if you remember.
I have a 69 with a real leaky set of old hookers. I've tried the dead soft aluminum gaskets, the Earl's gaskets, and the Fel-Pro's work best, with a little red RTV silicone. the dead soft Aluminum work for the collector's I've found.
PaPa Johns 77
Necoa #: 6188
PostPosted: Sun Jan 29, 2006 10:55 pm    Post subject: Reply with quote
Cool I've in the past even used 2 gaskets per side to make headers seal. The old AP or Blackjack headers. Cool
"Johnny"
Bradley, Illinois
Chief Smackaho
Necoa #: 7182
PostPosted: Thu Apr 06, 2006 11:15 am    Post subject: Reply with quote
Anybody having starter clearance issues? I put Flow Tech on my 83 full size and they were great when they weren't burning up starters, 1/4" clearance from header to solenoid.
PaPa Johns 77
Necoa #: 6188
PostPosted: Thu Apr 06, 2006 1:50 pm    Post subject: Reply with quote
Cool Go with a mini starter or try a heat shield. This seems to be a common problem when using headers. Sad
"Johnny"
Bradley, Illinois
quadrajetjunkie
Necoa #: 6649
PostPosted: Fri Jun 30, 2006 3:44 pm    Post subject: Reply with quote
My dad and I just put a set of Dynomax Blackjack full-length headers on my '79, and here's all the problems I could remember (quite lengthy):
-Had to fabricate a spacer for the rear a/c comp./power steering pump bracket that originally used an exhaust manifold bolt for mounting.
-Had to heavily modify the column shifter rod that runs from the steering column to the transmission linkage (got in the way of cyl. #7 tube), as well as clearance part of the transmission (TH350) shifter linkage for the collectors.
-Made a rough heatshield for the starter since one of the tubes was only about 1/16 inch away from it. Now I have to loosen the pass. side headers to remove the starter.
-Put some dents in the firewall on driver's side to get the headers in. Also had to remove the trans. crossmember to get the engine tilted down enough to get the headers in from the bottom. My dad also busted the plastic fenderwell with a hammer and punch because he was trying to put one side in from the top and he needed some clearance and he thought they were made of metal. But, um, that last bit wasn't necessary. I wouldn't recommend it.
-Went ahead and welded on a hot air pipe for the heat valve in the air cleaner to make it legal.
Here's my main advice: DO NOT buy full-length longtube headers if this is your first header job. Fifty percent of these problems would have probably never existed if I used shorter headers. Once I get more experienced, I might use them, but this time, it was a mistake. At least I learned something. Happy wrenching and God bless.
-One more thing: never confuse header noise for a lifter click and overadjust your valves and wipe out your brand new Comp camshaft and entire bottom end. Don't ask how I found that out.
izzoe46
Necoa #: 7809
PostPosted: Fri Jul 14, 2006 7:59 pm    Post subject: Reply with quote
I got some flo tech headers for my 81 also, I got a 350. I had to pound a small dent on one of the pipes on the passenger side and the flanges had to be cut to make room for the steering linkage.
My biggest problem is the last bolt on the passenger side by the firewall. I can't get that one on. I think flo tech skimmed on quality for production purposes.
I will buy new bolts and gaskets. Hopefully I can get that last bolt on because the pipes and cat back has all been welded already Sad
JimmyJ
Necoa #: 7565
PostPosted: Tue Jul 18, 2006 9:42 pm    Post subject: Reply with quote
I just installed some dynomax short style headers on my 85 with no problems. I recently replaced the motor mounts, so if yours are bad, then I can see some issues there. I had to modify the ac/ps brackets, but the headers came with instructions on how to do that. It's definitely worth it. I gained a whole lot of power. I also removed my cat and put true duals.
Kryp7ik
Necoa #: 11238
PostPosted: Wed Apr 23, 2008 5:32 pm    Post subject: Reply with quote
i just recently put some on my 78 g-body
i opted for the HOOKER competition longtube headers 1 5/8" - 3" collectors
and they did fit like a glove
going from underneath on both sides
drivers side slid right in
just had to replace the stock size oil filter with a shorter AC Delco one
passengers side i had to remove the starter
then it slid right in.
after i put the starter back in i realized that the headers were resting snug against the starter so i went down the road to see my friends at O'reillys and got me a "mini" starter for a i think 95 GM truck its like half the size of my old starter it slid right in with plenty of room to spare. i used the new hardware that came with the headers except for the bolt that the compresser bracket attaches to even though i dont have a compresser.
instead of using the single gasket that came with the headers i used 2 sets of felpro stock manifold gaskets on each side, sealed like a dream and sounds amazing! then i put dual exhaust with flowmaster mufflers and i didnt even use a double hump crossmember just "squeezed" the pipe a bit for ground clearence.
well thats my story hope this helps
all in all HOOKER is the way to go.
Kryp7ik
Necoa #: 11238
PostPosted: Wed Apr 23, 2008 5:36 pm    Post subject: Reply with quote
its easiest if you install the bolts closest to the firewall first i learned from first hand exprience. (i actually had to cut a wrench in half to even be able to get to it to tighten it!)
just a suggestion.
Redvetter
Necoa #: 9102
Year: 1966
PostPosted: Sun May 25, 2008 9:37 pm    Post subject: Reply with quote
I'm in process of putting Flow Tech headers on my '66. Drivers side fit OK. Passenger side is against the frame. Will try shimming the motor mount for clearance or will make clearance with a torch and a hammer and screw up the ceramic coating.
1964 Corvette
1966 El Camino
2002 Harley Heritage Softail
Page 2 of 3
Page Generation: 0.362 Seconds
