El Camino Central :: View topic - Building a .040 over 350, cam suggestions
johnnyhawk
Necoa #: 10830
PostPosted: Thu Feb 14, 2008 11:26 pm    Post subject: Building a .040 over 350, cam suggestions Reply with quote
Hi all. I recently started work on an 84 Choo-Choo Camino, the orginal
305 was replaced with a 350 with 40 over TRW pistons and Dart SS Heads.
I have an Edilbrock Performer RPM manifold, Edilbrock 650 CFM carb.
He also purchased a nice Holley fuel pump and Hooker coated headers. I am having the heads refreshed and he mentioned he would like to cam it.
So, have any of you run a mild street cam in a 350 small block with stock rockers and springs that wouldnt be more trouble than its worth? I am usually sceptical of doing just a cam and not the whole valve train, so ring in if you have an opinion I am mulling things over. Thanks all.
John
Largo, FL
( 70 degrees and sunny)
Johnny Hawk
Largo, FL
CANTED
PostPosted: Fri Feb 15, 2008 10:21 pm    Post subject: cam Reply with quote
With the motor oil issues, I would seriously think about changing over to a roller set up. I know it's pricey but the advantages are huge.
Jim
Elky77
Necoa #: 1971
PostPosted: Sat Feb 16, 2008 12:24 am    Post subject: Reply with quote
You're doing a nice rebuild, .40 over will leave very little drag, great heads, great carb, lots of fuel pumping: Why not breath it well.
I used a 3/4 race Crane cam with roller lifters, roller rockers and cam gears (no timing chain to get sloppy). VERY well worth the money. I've got about 40,000 miles on it after the rebuild, still starts and runs like the first day.
Make sure you add some kind of hot spark!
Let us know what you decide.
Elky77
Flaminmeano
Necoa #: 7482
PostPosted: Sat Feb 23, 2008 6:22 pm    Post subject: Reply with quote
You won't be satisfied until you stroke it Razz
385 stroker, brodix, weiand super charger,
2hndsmke
Necoa #: 10908
PostPosted: Tue Mar 04, 2008 12:47 am    Post subject: Reply with quote
I'd rather be blown than stroked Cool
69 tremec
Necoa #: 10275
PostPosted: Tue Mar 04, 2008 12:53 am    Post subject: Reply with quote
who says you cant have the best of both worlds...lol Poke Tounge
tim fraley
2hndsmke
Necoa #: 10908
PostPosted: Wed Mar 05, 2008 1:04 am    Post subject: Reply with quote
when I get stroked too much I get chaffed Poke Tounge just messin
rbohm
Necoa #: 11113
PostPosted: Wed Mar 05, 2008 10:21 am    Post subject: Reply with quote
Cool while i havent had problems in the past just changing cam and lifter and nothing else, i dont recommend it. i highly recommend changing valve springs to the ones the cam manufacturer recommends. you dont need roller rockers though as the stock rockers are good enough.
64 falcon
66 mustang
76 el camino
a mans fate is a mans fate
and life is but an illusion
69 tremec
Necoa #: 10275
PostPosted: Wed Mar 05, 2008 2:26 pm    Post subject: Reply with quote
ahahha thats a good one Laugh
tim fraley
PostPosted: Fri Apr 25, 2008 7:20 am    Post subject: Reply with quote
I'm not sure if your still working on this, but here's some info on the Comp Cams option I chose:
Summit Link
Spec Sheet
It's a nice street/strip cam, and you won't have to change your stock valve springs. The rule of thumb I was told is: keep the Cam lift under 1/2" and you shouldn't have to use heavier springs or screw-in studs. Over 1/2" is when you start putting more strain on the heads and valves and will need to beef them up. There may be more to it than that, but that's what I went by and I am very happy with my engines performance.
When I was a kid (in the 70's) I had a shirt that said
"Injection is nice, but I'd rather be blown"
I knew it was a cool shirt 'cause Mom didn't like it Cool
Elky85
Necoa #: 499
PostPosted: Sat Apr 26, 2008 12:09 am    Post subject: Reply with quote
when you say heads refreshed, does include some port work? Stock heads are going to crap out at 4500rpm.
If you're going to a roller, which is a good choice, the ZZ4 cam is an inexpensive option.
You might as well freshen the valve springs up, and .550 lift springs aren't that expensive.
Reazon
Necoa #: 8990
PostPosted: Sun Apr 27, 2008 8:04 pm    Post subject: Reply with quote
I have the bracket master 2 cam 00016 from lunati. I bought the appropriate valve springs from my local machine shop. I paid 35 bucks for the springs I can get you a part number if you'd like. I buddy on mine did the springs in about a hour and a half. I have a 350 with this stuff in it. I have a weind action performer intake. I also have an edelbrock 650 on my motor I haven't driven it yet do to needing to finish the exhaust and other little things on my car but I've only read good things about this cam.
