Necoa #: 10485
Posted: Tue May 06, 2008 9:22 am Post subject: Purple Wire 4 TCC, How does the Factory Hook Up W/Cruise
For a TPI conversion-
The Purple wire to the computer from the brake light switch.
With cruise control does the factory use a special brake light switch?
I know that there are two part numbers for the el camino one with cruise and one without. The one without cruise has two spades the one 'with' has four this allows for a normally open and normally closed circuit on the same switch.
