Necoa #: 9663
Posted: Sun
May 11, 2008 2:06
pm Post subject: More a/c drama
Your not getting any voltage to the compressor clutch to kick it in. Make sure it is plugged in at the compressor as well as the low pressure cutoff switch over by the receiver drier. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 9663
Posted: Sun
May 11, 2008 4:39
Necoa #: 9663
Posted: Sun
May 11, 2008 5:36
Glad I could get you going in the right direction. If the compressor wasn't kicking on when you were charging the system you probably just need to top it off. What low side pressure are you running now? Needs to be about 30. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 9663
Posted: Mon
May 12, 2008 8:35
Necoa #: 9663
Posted: Sat
May 17, 2008 4:16
