Posted: Sun
Sep 30, 2007 10:40
am Post subject: Window Sweeps Removal
_________________ 85 El Camino 305, TH350, K&N, dual exhausts
Posted: Sat
Oct 20, 2007 9:01
am Post subject:
I think you got lucky greywolf. It seems most door glass does not get low enough without removing the down-travel stop to access the screws. I know mine did not and that was with the interior panel removed.....Doug _________________ 85 El Camino 305, TH350, K&N, dual exhausts
Posted: Sat
Oct 27, 2007 7:23
am Post subject: Thanks
I need to do this also, alot of the books I have arent detailed are understandable to me lol, but reading how to do things from how others do is a great help thanks _________________ VROOM VROOM lets ride!!!!
I had to remove the glass in my '81. I had the window out while painting anyway, so it wasn't as big a deal for me. Taking the window out wasn't as bad as I thought it would be, I left the regulator in to avoid any more work than was necessary. _________________ My "Hell Camino" Homepage
"Attitude is everything"
On my driver door, I managed to finagle a screwdriver in there just by removing the inner felts and such... but the passenger was a different story, I wound up breaking off the ends of the felt, and just spinning it arround inside the door, thankfully it gripped the screw long enough for me to hack-saw it off.... I just didn't install the middle one again
Necoa #: 9679
Year: 1966
Posted: Fri
May 16, 2008 3:13
pm Post subject:
