Posted: Thu
Apr 10, 2008 10:35
am Post subject: Quadrajet info - more than you wanted to know
q-jet info _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 5673
Posted: Fri
Apr 11, 2008 4:54
pm Post subject:
Decent carb overall, just not a racing/high performance carb (though they can come close in some venues with a Q-jet expert and a great deal of TLC). _________________ 70 Elky (Non-SS) 454CID, TH700-R4
29 Model A (Recently Sold).
Posted: Sat
Apr 12, 2008 5:04
am Post subject:
exactly the same Jim. The duajet just doesn't have the secondaries on it. Just ignore anything pertaining to the secondaries and as you said in your post - You used the quadrajet metering rods to get it running. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 8721
Posted: Thu
May 15, 2008 9:13
pm Post subject:
BUT...i will not remove that power piston again until someone tells me the secret of getting both those metering rods back in the jets at the same time. There must be some secret, but I haven't found it yet and it takes 5 minutes of "fiddling" before they will suddenly just slide in. _________________ Jim
1983 El Camino
Put them in before you put the big plastic block in. You can see what you are doing. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 8721
Posted: Fri
May 16, 2008 9:25
am Post subject:
I cant do that. The piston and the two rods go through the holes in the block. If I disassemble them I cant see any way to reassemble them after putting in the block since they have to tilt to the side to thread them into the holes on the yoke??? Do I miss something here?? _________________ Jim
1983 El Camino
No your not missing anything. Some of the blocks are made that way. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
I wouldn't modify that block. It is easier to just pull the carb and make the changes you need and then put it back. by the time you pull the top there are only a couple of vacuum lines and two nuts to get it off where you can look down past the block and guide the metering rods into place. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 8721
Posted: Fri
May 16, 2008 4:10
pm Post subject:
No, I think rather than pull it all the way off I will see if I can find a block that was made that way, Or, since I have a spare from the Q-Jet, I might try modifying it and see what happens. _________________ Jim
1983 El Camino
