El Camino Central :: View topic - Help decode rear axle stamping...
SSKIDMARKSS
Necoa #: 7257
PostPosted: Wed Jun 25, 2008 10:13 pm    Post subject: Help decode rear axle stamping... Reply with quote
I looked at a rear end forsale the guy said was from a Gran National but I think it was the wrong housing with the finger indents on either side of the cover along the bottom edge. Its been a couple day and I didn't write it down but I think the stamping was " 2AC 0 300 " it also had a limited slip tag under a cover bolt. Any ideas what gear or housing ?
PostPosted: Thu Jun 26, 2008 12:40 am    Post subject: Reply with quote
I don't have the decode numbers for GN's but I thought someone on another thread said the GN's came with 3.23's as one of their axle options. I know camaro's and firebirds of that era had that ratio as standard with 3.73's as options on the Higher end packages.
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Thu Jun 26, 2008 5:23 pm    Post subject: Reply with quote
I see you have a 69 elky in your ID, a GN rear end will not be compatable with a 3rd gen elky anyway..
Ol Paint and me
454/700R4/3.31 posi
8.30 @ 82.23 / 60ft @ 1.82
AND
14.5 mpg average on HRPT 2006
SSKIDMARKSS
Necoa #: 7257
PostPosted: Thu Jun 26, 2008 10:27 pm    Post subject: Reply with quote
Yeah I need to fix my sig I have a 69, 79, and 85 the rear would be for my 85 because I plan on doing a tranny update to a 200r4 or a 350 turbo and get rid of the piece o crap th200.
EDIT:
I tried to update my sig but there is only one spot for model years so 69 it is......... it was the best year anyway ! Razz
PostPosted: Fri Jun 27, 2008 7:55 am    Post subject: Reply with quote
Did a little snooping online and found out the dealer option codes for the axle offerings in a Grand National.
Here they are:
GM8
axle ratio; 2.56:1
GU4
3.08:1 optional axle ratio
GU5
3.23:1 optional axle ratio
So it's likely one of those. The 2:56 would likely be for the autocross sort of GN owner or something... Confused
on another site I see a mention of a 3:42 axle avaliable as well. Here's a list of RPO codes and the axle stampings. THese should be in the ballpark..
THis is for the 78 to 88 model years
RPO |--------Axle Code--------|
Ring Gear-- Code-- Ratio-- Conventional-- Limited Slip
7.5 G72 2.14 2AK 2BK (aluminum brake drums)
7.5 GH2 2.29 2AH 2BH
7.5 GU1 2.41 2AJ,2AZ 2BJ,2BZ
7.5 GM8 2.56 2AA 2BA
7.5 GU2 2.73 2AB,2AX 2BB,2BX
7.5 GU4 3.08 2AC,2AV 2BC,2BV
7.5 GU5 3.23 2AD 2BD
7.625 GT4 3.73 2TF 2TH (Monte Carlo SS)
8.5 GU6 3.42 3TP 3TJ (T-Type, GN Std.)
8.5 GT4 3.73 3TG,3TE 3TR,3TX (442, GN Opt.)
8.5 GU2 2.73 8YB 8YP (B-Body)
8.5 GU4 3.08 8YD 8YR (B-Body)
8.5 GU5 3.23 8YE 8YS (B-Body)
Page Generation: 0.295 Seconds
