El Camino Central :: View topic - LS1 Fuel system
LS1 Fuel system
Bazaz
Necoa #: 1398
PostPosted: Thu May 01, 2008 9:58 am    Post subject: LS1 Fuel system Reply with quote
Hey guys haven't been on the site for a while, about to start back up on my 70 el camino project. Quick question on 02 LS1 single fuel rail system. Since there is no return line was wondering if the fuel system is as simple as a single fuel line with new tank and single tube sending unit and inline fuel pump. If anyone has got some insight on the whole issue of not having a return line that would be helpful.
Thanks again!
Poltergeist
Gallery Administrator
Necoa #: 478
PostPosted: Thu May 01, 2008 9:06 pm    Post subject: Reply with quote
My understanding there is a return line. But it is in the back just after the fuel pump. It allows fuel to continuously flow cooling the fuel pump. I don't know how it is setup though to make sure that the fuel going to the motor at pressure. Might be some kind of pressure control valve.
ECC Member #002
cherryelkyls1
Necoa #: 9806
PostPosted: Wed May 14, 2008 5:35 pm    Post subject: Reply with quote
Yes, in the stock application the pump has a regulator and return built in. I used a in-line pump and ran that line to a corvette filter/regulator, then you have your return and pressure lines. i ran the return back to the tank, and the pressure line up to the rail. Good luck.
1980 El Camino
2002 LS1, 4L60e swap
345hp, and 23 mpg.
vrooom3440
Necoa #: 3296
PostPosted: Sat May 31, 2008 2:06 am    Post subject: Reply with quote
Note that return-less EFI fuel systems are also done by modulating the electrical supply to the pump based on a fuel pressure sensor. I cannot tell you if this is the path chosen by GM for the LS1 or not, but I figure if Ford can do it then GM cannot be too far behind.
EL S ONE
Necoa #: 10110
PostPosted: Tue Jul 01, 2008 8:32 pm    Post subject: Semi return F.I. system Reply with quote
I run 04 Ls1 semi return system which is considered stock.A walbro 255lph is in the tank ,it pumps to a Corvette fuel filter/fuel pressure regulator located close to the tank . I think it maintains 45psi and returns unused fuel to the tank. This will work well if your F.I. is PWM ( pulsed width modulated) instead of a vacum operated fuel pressure regulator.
Original owner. "04" LS1. 4L60E. GN 8.5 3.73's. Eaton posi. Dual 2.5 Tubes & Flowmaster 50's. Electric antenna. C.A.R.B approved.
Page Generation: 0.828 Seconds
