El Camino Central :: View topic - Dash pad R&R
Dash pad R&R
just plain john
Necoa #: 11645
PostPosted: Wed Jun 04, 2008 6:11 am    Post subject: Dash pad R&R Reply with quote
I'm pulling the dash in my 81 for the first time. I went looking for an El Camino chiltons manual, but the best I could do was a Chiltons manual for a Monte. Not very specific or helpful. I searched 'dash pad' without much success, however the sticky under the topic 'electrical' there was a 25 step procedure for gauge pod R&R. Seems complicated for a novice. I find that I'm pretty good at taking things apart, but getting them back together still needs some work. Any resources or tips out there in El Camino land?
just plain john
Necoa #: 11645
PostPosted: Wed Jun 04, 2008 6:12 am    Post subject: Reply with quote
I forgot to ask....any special tools required?
PostPosted: Wed Jun 04, 2008 6:43 am    Post subject: Reply with quote
follow this link and then there is another one down in the thread you can follow for more info.
just plain john
Necoa #: 11645
PostPosted: Wed Jun 04, 2008 6:14 pm    Post subject: Reply with quote
Hmmmm, it looks like the link didn"t post.
just plain john
Necoa #: 11645
PostPosted: Wed Jun 04, 2008 6:15 pm    Post subject: Reply with quote
Whoops, my bad, yes it did. Duh....
just plain john
Necoa #: 11645
PostPosted: Wed Jul 09, 2008 11:18 am    Post subject: Reply with quote
OK, the dash is loose everywhere, bot it still won't come out. There is a support at the steering column that is riveted to the dash. This support appears to be sandwitched between 2 other pieces of sheet metal of a similar half circle shape. The upper piece of these 2 has 2 captive bolts that the steering column is secured to, then the dash supports, with a third piece below that. Let me go get a pic and I will post it up
just plain john
Necoa #: 11645
PostPosted: Wed Jul 09, 2008 11:33 am    Post subject: Reply with quote
Those bolts are welded in, so I can't drive them up so the middle piece can slip out. Hey, how do I post a pic on this site? I don't see an attatchment button.
PostPosted: Thu Jul 10, 2008 7:32 am    Post subject: Reply with quote
Yes, the bracket that is riveted to the dash pad and "sandwiched" by the steering column supprt and dash support bracket will need to slip out.
There should be 2 nuts (one on each side of the column) that you can loosen from the bottom. You don't need to pull them off completely, just back them out quite a way. Then you'll have to pull on the dash a bit and wiggle it out. You can use a prybar to help spread the upper and lower clamping brackets, just be careful not to rip the bracket off the dash pad or bend the other brackets.
When it's time to put it back together, make sure you get the bracket fully inserted back in place, and watch your harness wiring and radio antenna routing. It's real easy to pinch some of the wires.
just plain john
Necoa #: 11645
PostPosted: Thu Jul 10, 2008 12:53 pm    Post subject: Reply with quote
So the "sandwiched" bracket has slots instead of holes? Never had one out before and as noted already the bolts are tacked into place so I can't pull them unless I cut the tack first.
PostPosted: Fri Jul 11, 2008 3:11 am    Post subject: Reply with quote
Yes, they are slotted holes (sorry, should have included that).
