El Camino Central :: View topic - FI options for a 99 Vortec
Redster
Necoa #: 7055
PostPosted: Tue Dec 18, 2007 9:37 pm    Post subject: FI options for a 99 Vortec Reply with quote
Texas Flag I have a 99 vortec we just finished. Been advised that the only reasonably priced fuel injection option is to go back with the 'Spider' sys. Before I do that, are there any other ideas or advice?
Thanx,
Red
the RED one
PostPosted: Tue Feb 26, 2008 7:05 pm    Post subject: Reply with quote
What type of system do you want to run? The aftermarket has both TPI and TBI bases for the Vortec heads.
Redster
Necoa #: 7055
PostPosted: Wed Feb 27, 2008 10:02 pm    Post subject: Vortec FI Reply with quote
My preference would be TPI but the answer I got from the FI Specialist who is going to set it up was that options other than the 'spider' were cost prohibitive. I just bought the spyder last week from my local GM performance shop. I got this vortec from a friend but also found it to be an easy and less expensive find than an LS engine. With the machine shop friends I have, the FI system has the potential to close the LS - truck engine gap quickly. I am still very interested in options as this is a father/son project and mine may follow soon.
Cool
the RED one
PostPosted: Wed Feb 27, 2008 11:01 pm    Post subject: Reply with quote
I cant imagine anything from the GM Performance shop being any cheaper then the aftermarket. But, the only TPI bases I know of for the Vortec heads are the Holley Stealth Ram and the Edelbrock TPI base. Both use GM sensors and injectors so wiring is fairly easy. Either of these would be a set up over the L98 350 TPI motor with a good cam and the Vortec heads. Just make sure you get a good tune and use a wideband O2 sensor if possible.
PostPosted: Wed Feb 27, 2008 11:03 pm    Post subject: Reply with quote
One more thing. If you look around on thirdgen.org you may find a good deal on some used parts.
PostPosted: Thu Feb 28, 2008 5:05 pm    Post subject: Reply with quote
Redster:
I saw an add for a new EFI set up from Edelbrock. Cant find it on their website yet. But it looks like an LT1 set up with short runners. More for higher RPM power then the stock long runner low end torque set up. anyway, they say they have them for Vortec heads as well as the standard 23 degree SBC heads.
Redster
Necoa #: 7055
PostPosted: Fri Feb 29, 2008 9:03 pm    Post subject: Reply with quote
Wow, thanx for the info. That Holley Stealth is an awesome set-up. I am sure the Edlebrock is too. I'll do some data mining to see what they have for the Vortec. Since this one is for my son, we will probably stay with the spyder injections sys. but I am taking lots of notes for mine which I hope follows quickly. If I had seen the Holley before we went back stock, I'd be chopping a hole in the hood for that 58mm vacuum to breathe. Again, I really appreciate the help. Cool
the RED one
PostPosted: Fri Feb 29, 2008 11:18 pm    Post subject: Reply with quote
One more thing. I have heard there is hood clearance issues with the Holley set up. It will not clear a stock hood. It may not clear the 2 1/2" Goodmark cowl hood either. I'm waiting to hear from a guy from the monte ss site if it clears his hood.
Redster
Necoa #: 7055
PostPosted: Mon Mar 03, 2008 7:52 pm    Post subject: Reply with quote
cool, and like I said I'm taking notes for mine. My son wants to stay with a stock hood so our set up will work for that. I however want a cowl hood but want to stay as low as possible ... therefore interested in hearing how your friend cleared. Good info Cool
the RED one
Pyromanaron
Necoa #: 9726
PostPosted: Wed Jul 09, 2008 10:41 pm    Post subject: Reply with quote
The only Edelbrock EFI set up I know of is their "Pro-Flo". I plan on using that.
Peace through superior firepower
Page Generation: 0.458 Seconds
