backpressure??
Goto page Previous  1, 2
elcamman006
Necoa #: 10766
PostPosted: Tue Apr 15, 2008 11:16 am    Post subject: Reply with quote
ok thanks guys, sorry i didnt mean to cause chayos
Snaggle To0th
Necoa #: 4293
PostPosted: Tue Apr 15, 2008 1:51 pm    Post subject: Reply with quote
It's all good! Welcome to the ECC
Proud Wyotech Graduate
conquista90
Necoa #: 7515
PostPosted: Tue Apr 15, 2008 6:38 pm    Post subject: Reply with quote
elcamino74guy wrote:
Haha, my car does that and I was wondering if it meant something was wrong... I'm glad it doesn't cause I think it sounds cool.
Snaggle To0th
Necoa #: 4293
PostPosted: Wed Apr 16, 2008 12:17 am    Post subject: Reply with quote
well if you have a air injection pump installed...reasoning being for that after firing is due to a faulty air injection pump! The un burned gas that left teh cylinder is getting burned up Poke Tounge
conquista90
Necoa #: 7515
PostPosted: Wed Apr 16, 2008 3:54 pm    Post subject: Reply with quote
Nope. Just a straight non-emissions 350. 80's truck block with camel humps. Stock exhaust manifolds and a leaky single exhaust.
Snaggle To0th
Necoa #: 4293
PostPosted: Wed Apr 16, 2008 5:03 pm    Post subject: Reply with quote
could be ur exhaust leak but other than that still coo! I liked hearing my after firing puffs when my smog pump was defective!
El Monstero
Necoa #: 11902
PostPosted: Thu Jul 10, 2008 8:09 am    Post subject: Reply with quote
At low rpm's no back pressure will allow more low end torque, because there's no resistance on your engine to breath the air it needs to burn the fuel. At high speeds no back pressure will cause your engine to have less horse power and more torque, that lowers top speed. When you have no back pressure you get more off the line power, when you have a good induction, getting enuf air through your carb, or throttle body. The X-pipe I have heard, with balance the pressure, between dual exaust because each side has different back pressure, & the x-pipe balances the exaust pressure, wich means more power. If you add some good mufflers like Edelbrock's Ti-Tech SDT 304's you will have some back pressure, but not too much. With high end heads, and good headers, you will see a nice gain, with great air flow, now re-tune your carb when your done-(Happy engine=Happy driver).
El Monstero
Necoa #: 11902
PostPosted: Thu Jul 10, 2008 8:46 am    Post subject: Reply with quote
I have alittle more tech. info on this subject- & I have a LOT more tech. info.
"Backpressure and scavenging ability can easily get confused. [/U] If you build a system with no backpressure, you'll end up with a system with no scavenging ability. The trick is to find the fine balance between the two. The bottom line is on a normally aspirated engine, too big results in poor performance....practical experience has told me that."
"Scavenging has much to do with size and length of header runners but the size of the system beyond that may have some substantial impact as well."
"Cylinder Scavenging, backpressure etc all has to do with manifold/extractor/header design, once your past that point, you want as much flow as possible.
What some seem to overlook though, is that often header design needs to extend to well under the car depending on where in the rpm band you want to make good power."
szonk
Necoa #: 5244
PostPosted: Thu Jul 10, 2008 8:43 pm    Post subject: Reply with quote
In english please, how does a basic system using factory manifolds on a 305 with 2 1/2" pipes with X and flowmaster 40's would work, and will that suffice when a 350 (w/headers) is installed at a later date ? Thanks !
Chillin in Lauderdale
Snaggle To0th
Necoa #: 4293
PostPosted: Mon Jul 14, 2008 7:37 pm    Post subject: Reply with quote
Your question doesnt speak english as well, but in shorter term if you go to big with a free flowing exhaust you will lose power in theory. So if you have a street engine mild build 1 5/8" headers then a x pipe and flow masters and teh x pipe in the correct location and wiht 2 1/2" exhaust tubing you will have no back pressure existant nor having air being sucked in into the exhaust being the scavinging effect so I belive.
-Anduh
Page 2 of 2
Page Generation: 0.332 Seconds
