Posted: Mon Jul 14, 2008 5:38 pm Post subject: Latest engine oil grade SM promotes cam wear
I heard about this through the GTO Association of America, but the latest grade of engine oil, SM, does not contain ZDDP. This molecule, which was in quality oils for the last 70 years, reduces sliding friction on flat tappet engines on the cam surfaces and also in the crank and rod bearings. I've read of camshafts wearing out in 900 miles!
Previous grades had 0.12% (SG) and 0.15% (SF) ZDDP by weight.
Apparently new cars with roller rocker set-ups don't need ZDDP and the zinc and phosphates in the additive can degrade catalytic converter life, so its been done away with.
My daily driver is an 87 El Camino with 326k miles and I'm not ready to give it up!
There are ZDDP additives available but that means the cost of an oil change just went up by $10 ($9.95 for a 4 ounce bottle).
OK - Thanks! I did a search on ZDDP but didn't find anything.
I tend to buy oil in the 5 Qt containers and haven't seen the older grades, and besides, they won't be available forever.
I read through the string and several links but still have a question: Assuming this is a real concern and I should use a ZDDP additive to prevent cam etc wear, does that mean I'm going to ruin my catalytic converter?
Thanks for the reply!
That's what I was thinking - unless the oil is getting into the exhaust, the converter wouldn't know the difference. But I was surprised to see this in the literature I was reading. One of the reasons they gave for eliminating the additive was that new car manufacutrers needed to warranty the converter for 100,000 miles and this could degrade that life.
I change my oil every 3000 miles and its down about half a quart so I shouldn't have a problem.
Necoa #: 11368
Posted: Mon Jul 21, 2008 11:24 pm Post subject:
Haha, what cat convertor? Mines been gone for a couple years or more. Deisel oil still has what you need in it, Rotella T and Delo 400 are a couple examples you can still get at WalFart.
