El Camino Central :: View topic - Gotta have some gears
sccountryboy2004
Necoa #: 3565
PostPosted: Wed Jul 16, 2008 10:07 pm    Post subject: Gotta have some gears Reply with quote
Hello everybody, I need some help or input on finding a good limited slip rearend that will work in my Caballero. I just put in a new 700r4 transmission in my Cab and my rear end is killing me. I mean the rear end in my car. It's got the stock 241 gears which is too high to work with my new 700r4. From what I've found out a set of 373's or 342's would be the best gear to run. I'm ready to start my search and was wondering what other vehicles would have a rearend that would work in my Caballero. I've heard that late 90's round bodied 4WD blazer's have posi or LS rearends, possibly with the right gears, that will work and some even have disc brakes. I've also heard that the insides out of 3rd gen Camaro's rear end will work inside the stock housing on mine. Can someone please steer me in the right direction. What are my options. Thanks for any help.
1986 Conquista
1987 Caballero
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Thu Jul 17, 2008 6:01 am    Post subject: Reply with quote
If you want a whole axle housing to direct fit to your Elky, 82 to 86 Monte Carlo, Olds Cutlass, Buick Regal, or Pontiac Grand Prix will work. Ring and pinions from any 7.5 axle will work from S-10 or Camaro/Firebird will fit. I have a 3.42 ring and pinion in my garage you can have for free, and you could buy any posi unit you like.
sccountryboy2004
Necoa #: 3565
PostPosted: Thu Jul 17, 2008 6:00 pm    Post subject: Reply with quote
Thanks for the reply Hans. I'd love to find the whole axle housing with 373 or 342 gears, limited slip with disc brakes all together. I could just swap the whole thing out and be done but I'm probably going to have hard time finding one. I'm probably going to end up buying a Detroit Locker limited slip unit and add my gears and forget about the disc brakes for now.
Does any of the direct bolt in's you mentioned come with disc brakes?
I'm very interested in the set of 342 gears you have Hans. I'll send you a PM on that. Thanks.
1986 Conquista
1987 Caballero
PostPosted: Thu Jul 17, 2008 6:29 pm    Post subject: Reply with quote
No factory "G" bodies with rear disc brakes. You'll have to adapt a set or buy aftermarket. Also, I dont believe Dtroit Lockers are made for GM "C" clip axles. But I could be wrong here.
sccountryboy2004
Necoa #: 3565
PostPosted: Thu Jul 17, 2008 9:31 pm    Post subject: Reply with quote
I was afraid of that. I couldn't remember hearing of disc brake on any G bodies but hoping I might be wrong.
I was looking through my summit cataloge and saw that they have a Detroit Locker called the "Truetrac" differential. It's made for GM 10 bolt, 7.5, 28 spline. I'm not sure what spline's the El Camino's have but If I don't use a detroit locker I know somebody makes limited slip's for my G body. Thanks for the reply.
1986 Conquista
1987 Caballero
PostPosted: Thu Jul 17, 2008 10:38 pm    Post subject: Reply with quote
Detroit Locker, Detroit Tru Trac, and EZ Locker are all made by the same company. They are all "posi" or "limited slip" carriers. They just happen to operate a bit differently. Yes, there are a few to choose from for the G body rear ends. I believe the spline count is 26 but wont swear to it.
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sun Jul 20, 2008 6:27 am    Post subject: Reply with quote
Going to be at Port of Charleston on Tuesday. Let me know if you want to meet somewhere to get these gears. PM sent
MC87SS
Necoa #: 10964
PostPosted: Sun Jul 20, 2008 9:03 am    Post subject: Reply with quote
82-88 G-Bodies 7.5s are 26 slpine.
I have a Brand new Thorson posi unit for a series 3 carrier.
This unit is a 28 spline unit but i also have a set of 28 spline axles for a grand national. I bought this to put into my monte but found a complete rear instead. $300 plus actual shipping via UPS.
This unit was a factory upgrade in the F-Bodies. IIRC these units were almost $700 from the dealer.
80 ElCamino / Blue-Blue 454-400 Trans
87 Monte SS / Black-Saddle T-Tops
85 Monte SS / Black-Gray T-Tops (Wifes Car)
SMCC Florida Chapter
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sun Jul 20, 2008 2:47 pm    Post subject: Reply with quote
Heres a pic of what I'll be driving. Posi unit from MC87SS is a hell of a good deal!
sccountryboy2004
Necoa #: 3565
PostPosted: Sun Jul 20, 2008 8:21 pm    Post subject: Reply with quote
It won't be hard finding that Rig. Thats a nice truck. I'd hate to have buy a set of tires for that thing. I'll be driving my blue Caballero.
That is a good deal on the carrier and axle set MC87SS has. I'm very interested in those also. I'll be shooting him a PM here shortly.
Thanks for all the help.
1987 Caballero
1986 Conquista
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Mon Jul 21, 2008 7:08 pm    Post subject: Reply with quote
Sorry Glenn, but my load has been postponed due to the ship being late, getting to port. Crying Must be because of the storms in the Atlantic. Will find out Tuesday, if its a go for Wednesday. Will keep in touch with you. Got your ring and pinion on the truck floorboard for when I get there. Any chance you have a set of tailgate cables? Cool Later, Hans
sccountryboy2004
Necoa #: 3565
PostPosted: Mon Jul 21, 2008 7:59 pm    Post subject: Reply with quote
Thats not problem at all Hans. I'll gladly work with your schedule. Just give me a call when you're ready. I'll have a pair of tailgate cables for you.
1987 Caballero
1986 Conquista
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Wed Jul 23, 2008 5:32 am    Post subject: Reply with quote
Just have to be patient now Glenn.... Charleston load was given to another driver. I do get down that way, so I'll leave ring and pinion in the truck, and call you when it happens.....PROMISE!! Cool Heading to Houston TX this morning Crying Hans
sccountryboy2004
Necoa #: 3565
PostPosted: Wed Jul 23, 2008 9:22 pm    Post subject: Reply with quote
Not a prob Hans. I'm in no big rush to get the gears. I've got to get the posi unit and axles first anyway and thats still going to be a couple of weeks away. I'll shoot you a PM.
1987 Caballero
1986 Conquista
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Tue Aug 12, 2008 7:36 pm    Post subject: Reply with quote
Haven't forgot about you Glenn..... Still have ring & pinion rolling around floorboard of the truck. No clue when I'll get down your way, but still have your number in my wallet for when I do. Cool Hans
