Phoenix
El Camino Central :: View topic - Ignition Cylinder Issues.
Post new topic   Reply to topic    El Camino Central Forum Index -> Ignition Upgrades & Discussion Forum
XbeasleyX
Necoa #: 4285
PostPosted: Sun Jul 13, 2008 10:44 am    Post subject: Ignition Cylinder Issues. Reply with quote
My ignition cylinder seems to be messed up - the key can (and has been able to) be removed once ignition is turned past the lock. Now the issue is that the cylinder won't turn all the way towards me to the "lock" position, I've tried turning the wheel, moves fine no change to cylinder condition. Also the cylinder will not rotate to the start position, just stops no spring action at all.
My car is quicker than It needs to be, but I'm still making it faster.
CANTED
PostPosted: Mon Jul 14, 2008 9:11 pm    Post subject: ignition switch Reply with quote
There is a rod that connects the lock to the switch. You may want to try disconnecting it to see which end is binding up.
Jim
XbeasleyX
Necoa #: 4285
PostPosted: Wed Jul 16, 2008 7:52 am    Post subject: Reply with quote
Do I need to pull the steering wheel to check that?
CANTED
PostPosted: Thu Jul 17, 2008 6:59 pm    Post subject: ignition switch Reply with quote
Should not need to. The switch is mounted to the top of the column about half way to the floor. The rod runs from the lock down to the switch. You may need to remove the switch from the column to disconnect it. (kind of a pain to get to) Then work the lock to see if it is ok.
Jim
Post new topic   Reply to topic    El Camino Central Forum Index -> Ignition Upgrades & Discussion Forum All times are GMT - 6 Hours
Page Generation: 0.630 Seconds
