El Corvino
Necoa #: 9422
PostPosted: Fri Jul 18, 2008 6:03 pm    Post subject: HELP!? I am sooo lost but have cool stuff Reply with quote
Can someone please help me... as I can not get technical assistance anywhere else. (nobody seems to know!?!?)
I spoke with a few people who got me to doubt myself, so please help before I begin my install.
I went with the "you only live once" theory and decided to do a 2 stage progressive shot on my fully built 383... so I should be putting some serious power to the ground.
I have (had for too long lol) for the front
2" beltech drop spindles
new stock height springs
QA1 adjustable shocks
for the rear...
QA1 DR2000K coil over system... for 2300-3100 lb. Vehicles
Double adjustable upper and single adjustable lower control arms
8.5" rear end with detriot true trac something or another with 3.73's
and all bushings will be polyurethane.
Rims and tires!
Front 19x8
Rear 20x10 with nitto drag radial 305/35/20 (yes the frame is notched)
Is this essentially the ideal set up for cruising on the streets and maybe a drag race every 6 months? If this is going to ride like garbage, please tell me. If there is a significant way to increase traction and keep it streetable, please tell me. If you have a way for a 3% traction gain and 2% ride quality gain, please keep it to yourself. If you are a name brand chearleader and think i should have gone with your brand, please keep it to yourself... it will only confuse me further. Thanks for everyones help!
1982 El Camino - Parts car
2005 Ford Ranger Edge
2006 Ford Ranger
El Corvino
Necoa #: 9422
PostPosted: Fri Jul 18, 2008 7:36 pm    Post subject: Reply with quote
Hmmm... I talked to some of my friends down here who are big into street and track racing. they all agree that this seems to be the optimal set up for street use.
With the QA1's and can adjust the shocks through 12 different levels of stiffness / looseness. This should allow for a cadillac ride or C6 stiff ride. Also, the poly bushings should allow for some darn good handling.
your thoughts?
PostPosted: Sat Jul 19, 2008 8:17 am    Post subject: Reply with quote
I think your pretty much in there with the suspension mods and the 8.5" rear, but I notice no mention of either front or rear sway bars and jounce bars on the front. Also it seems you haven't addressed body twist issues. Installation of polyurethane body mounts (not gonna help ride quality) and rear strengthening of the rear section of frame (since you notched it). Even though they're full frame cars, they can still twist when your running what you are.
El Corvino
Necoa #: 9422
PostPosted: Sat Jul 19, 2008 1:40 pm    Post subject: Reply with quote
yay! someone who can help me!
I have the stock sway bars... but will likely upgrade them soon.
what the heck is a jounce bar? what does it do? no frame support to the back... I didn't notch to the skin and I'm not launching on slicks at the track... ever.
- Mike
PostPosted: Sat Jul 19, 2008 3:14 pm    Post subject: Reply with quote
Jounce bars triangulate the frontend for additional strength, they go from the frame rail to engine cradle (one each side) You can find them pretty easy at a boneyard on a lot of other G body cars...cheap. Did you box the notch or just cut? Also you might want to fab a frame connector (frame rail to frame rail) between the rear bumper and fuel tank, especially if your planning on a fiberglass bumper or roll pan. Check www.kirbanperformance.com for some nice add-ons to what you have. Remember what works on a GN or GNX suspension can pretty much work on a 5th gen Elky as well.
El Corvino
Necoa #: 9422
PostPosted: Sat Jul 19, 2008 4:04 pm    Post subject: Reply with quote
I don't want to add/weld anything else to my frame. Bolt ons are good though. I just had it powder coated and it cost me a grand haha no more welding! If you check my thread (the sticky in suspension) you will see it is very strong, boxed the frame... didn't just cut and grind
As far as the add ons go, I will def. look into that.
I have NO luck in boneyards here in south florida... most cars are stripped by employees before they hit the yard. Sad
El Corvino
Necoa #: 9422
PostPosted: Sat Jul 19, 2008 5:46 pm    Post subject: Reply with quote
EVERYONE!!
Whats your thoughts on... (for control arms upper and lower)
LAKEWOOD BOLT-ON LIFT BARS/LOWER CONTROL ARMS
and
Lakewood 78-87 GM "G" Body Adj Upper Control Arms
or should i just do UMI double uppers and single lowers?
PostPosted: Sat Jul 19, 2008 11:53 pm    Post subject: Reply with quote
Why do you need all the adjustability? I would think adjustable uppers to set pinion angle would be enough. Am I missing something? I like the Currie Trac upper and lower control arms. They have urethane bushings on one side and their "Johnny Joints" on the other. The offer a bit more range of motion then straight urethane bushings on each end of the control arms. They also have the holes to mount the stock sway bar. Only other thing you might consider is a set of lower control arm mount relocation brackets. This will help rear end geometry with a lowered car.
El Corvino
Necoa #: 9422
PostPosted: Sun Jul 20, 2008 4:54 am    Post subject: Reply with quote
I want all the adjustability because I see it as $100 difference here and there. I am assuming if everything can be dialed in to the most desireable point, then the car will be optimal. I am building the car for myself and want the best of the best of the best.
- Mike
- Where would I find the relocation brackets?
PostPosted: Sun Jul 20, 2008 11:06 am    Post subject: Reply with quote
Spohn and BMR have the relocation brackets.
El Corvino
Necoa #: 9422
PostPosted: Sun Jul 20, 2008 8:03 pm    Post subject: Reply with quote
darn... I just looked into the Lower Control Arms Relocation Brackets. Are they really that benefitial? I just had my rear end powder coateed and the last thing I want to do is tear into it and weld relocation brackets on it... or do they make bolt on ones?
- Mikr
El Corvino
Necoa #: 9422
PostPosted: Sun Jul 20, 2008 8:17 pm    Post subject: Reply with quote
wait... the SPOHEN one looks like it welds to the INSIDE of the LCA... I guess O could have it welded in and then just have that painted black? Or would that look odd?
PostPosted: Sun Jul 20, 2008 8:35 pm    Post subject: Reply with quote
Never used them so I cant say how well they work. I think they would look fine if you welded and then painted them.
El Corvino
Necoa #: 9422
PostPosted: Sun Jul 20, 2008 9:03 pm    Post subject: Reply with quote
Wait a sec... I am looking at pictures of lift bars....
IS it me, or is a lift bar essentially a control arm with the relocation bracket on it?
If thats the case, I may as well go with lift bars for my lower control arms and then just buy adjustable upper control arms.
PostPosted: Sun Jul 20, 2008 9:32 pm    Post subject: Reply with quote
Post a link or pic and lets see what they look like.
