Necoa #: 11858
Posted: Thu
Jul 24, 2008 3:28
pm Post subject: Wiring power to the fuse box
I am wanting to rewire the power to the fuse box.I am not getting any power to it at all.Where does the power connect to the fuse box is it where the slot labled batt is ,or does it wire in from the back.Will I need to remove the fusebox to do it.I t is a 1979 305 Thanks
It is fed directly from a fusible link that connects onto the starter positive terminal with the main cable. Check there first. If the fusible link looks all swollen or if you pull on it a little and it is stretchy then it has burnt in to. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
