El Camino Central :: View topic - Water and Oil sender
dedub
Necoa #: 12172
PostPosted: Sat Aug 23, 2008 2:03 pm    Post subject: Water and Oil sender Reply with quote
I would like to install a gauge package in my 80 ss but here is my question.
The original 305 is gone and it now has a target master. The oil sending unit that runs to the factory dash gauge is screwed in on the left/drivers side of the vehicle just above the oil filter. Is there another location I could use to hook up a second gauge for oil pressure?
Next question pertains to the water temp. Again, the factory gauge is run to where it is usually, below the headers between spark plug 1 and 3. Is there another spot to plug in a temp. sender?
Darrin
80 Elky SS
http://www.networxcomputer.net/elky/elky.html
hel98
Necoa #: 10617
PostPosted: Sat Aug 23, 2008 4:47 pm    Post subject: Reply with quote
There's an oil port on the rear of the block to the left of the distributor. It's 1/8 npt. You'll probably need a four or eight point socket to get it out without rounding it off.You can also use a brass tee fitting with a nipple at the port above the oil filter. It's 1/4 npt IIRC.
Depending on the type of intake manifold you have,there may be an unused port. If not, you can remove the plug from the other head.
My ride pics
360 TPI/ 4l60
dedub
Necoa #: 12172
PostPosted: Sat Aug 23, 2008 5:08 pm    Post subject: Reply with quote
thanks hel98
I found the 1/8 port, thats perfect. I couldn't use a T though because the factory is an electronic sender and I will be using a mechanical. Ill look for the other plug on the opposite side of the motor for the temp.
That's a nice ride you have too.
If you dont mind I'de like to PM you with some questions.
Darrin
80 Elky SS
hel98
Necoa #: 10617
PostPosted: Sat Aug 23, 2008 5:57 pm    Post subject: Reply with quote
Thanks. PM ahead.
My ride pics
360 TPI/ 4l60
