El Camino Central :: View topic - Tailgate Removal
Tailgate Removal
mars907
Necoa #: 12237
PostPosted: Thu Aug 07, 2008 9:50 pm    Post subject: Tailgate Removal Reply with quote
Hey guys, I'm in the process of stripping down my 74 Elky for restoration. Does anyone know the best way to remove the big phillips head screws that hold the tailgate hinges on. I tried a #3 phillips and it was too small. Any ideas would be appreciated, I really don't want to mess these up as I have a feeling they would be very difficult or impossible to replace. Thanks
sccountryboy2004
Necoa #: 3565
PostPosted: Thu Aug 07, 2008 10:21 pm    Post subject: Reply with quote
You're going to need to use an impact driver to get those out. I'd soak them down with some penitrating oil first. An Impact driver is a tool that looks like a big round peice of steel that you hold in your hand and it has a 3/8 drive socket attachment on one end. Most tool dealers have them and they usually come with a couple different size phillips head tips, including that big one on your tailgate. Anyway, you put the big tip in the screw, hold in in place tightly while putting as much pressure as you can in the direction you want to turn it and smack it on the end with a big hammer. You might want to practice on something else first. Good luck.
1987 Caballero
1986 Conquista
elkiebob
Necoa #: 10177
PostPosted: Wed Aug 13, 2008 8:15 pm    Post subject: Reply with quote
Hate to say it, but the big phillips worked on mine. Didn't have to use penetrating oil at all.
I didn't touch it. I swear.
Caveman49
Necoa #: 1780
PostPosted: Fri Aug 15, 2008 5:43 pm    Post subject: Reply with quote
A really BIG phillips will work if they're not froze up, thus the WHACK like sccoutryboy mentioned.
Mine wouldn't come out even after doing all the above, soooooo, I took a die grinder and cut slits in them, then used a big pry bar type screw driver. It worked great, a little armstrong and they begged to come out Laugh but I'll need new bolts.
Good luck with it.
74 El Camino 454/400turbo work in progress!
mars907
Necoa #: 12237
PostPosted: Sat Aug 16, 2008 12:02 am    Post subject: Reply with quote
Good luck with it.
Yeah, thought about doing something like that, but like you say the problem will be finding replacements. I found a #4 phillips socket attachment at Sears that I think I'll try, hopefully that will do the trick. Thanks for the input.
Low75
Necoa #: 4203
PostPosted: Sat Aug 16, 2008 11:21 pm    Post subject: Reply with quote
^That's what I used to remove mine...got it from Sears too. That plus a breaker bar and you'll have that tailgate off piece of cake.
1975 El Camino
http://elcaminocentral.com/gallery-album_album358.html
PostPosted: Thu Aug 28, 2008 3:37 am    Post subject: Reply with quote
I got 3 of them out with an impact driver with a big phillips head bit. The last one was impossible even with a torch. I ended up cutting flats on both sides of the bolt (it took a really long time) a big pair of vice grips and a breaker bar to get it out.
I replaced mine with grade 8 bolts. Just matched up the threads. No problems with interference and once I repainted the El nobody noticed the difference.
Page Generation: 0.306 Seconds
