Necoa #: 12262
Posted: Wed Aug 20, 2008 7:30 am Post subject:
I live in Winona, MN. Not real sure how to post a pic here but I do have this frame listed on craigs list under the Minneapolis section, you can see the pic there. Thanks.
Hi What year is the frame from? what engine? Then I won't have exstra holes that I don't know what they are for. Do you have the A frames too? Thanks for your time.
Necoa #: 12262
Posted: Thu Aug 28, 2008 8:04 pm Post subject:
THE LAST NINE OF THE VIN THAT IS STAMPED ON THE FRAME IS _ _ _ _1AR410588. THE SECOND DIGET IS "A" WHICH MAKES IT A 1980. I AM NOT REAL SURE ON THE ENGINE SIZE WHICH IS THE FIRST NUMBER IN THE LAST NINE BECAUSE THERE IS NOT A ONE FOR AN ENGINE SIZE BUT THERE IS A L WHICH WOULD BE A 350CI. IT SURE LOOKS LIKE A ONE ON THE FRAME BUT SINCE THERE ISNT A ONE ON THE VIN DECODE IT MUST BE A L. EATHER WAY I DONT BELIEVE IT WOULD HAVE ANY MORE HOLES THAN YOURS BECAUSE THEY NORMALLY HAVE HOLES FOR ALL OF THE ENGINE/TRANSMISSION COMBINATONS. AS FOR THE A FRAMES THIS FRAME DIDNT COME WITH ANY WHEN I PURCHASED IT. IF YOU WOULD LIKE TO KNOW MORE ABOUT THE FRAME YOU CAN CALL ME AT 507-459-1432 OR SEND ME YOUR NUMBER AND I WILL GIVE YOU A CALL. THANKS, ROD.
