Nothing wrong with a TH350 with the right rear axle ratio ie. 2.41, 2.73. If I was going to buy a trans I would go for a 200R4, same length as the TH350, no drive shaft length mods required and a very good transmission. As I recall the best ones are '86 and later.
Can't tell you much about the 700R4, but I doubt it would be troublesome behind a 305 engine.
Just like Doug said you will have to modify your drive shaft and change your shifter. 350 has 1 2 D and the 700 has 1 2 3 D . The cross member will have to move. _________________ www.cprstreetmachines.com
T-70 TURBO INSTALL EARLY NOV
SAN DIEGO, CA
Clean the front of the right axle tube near the differential housing and post the letters and numbers here. The codes will tell what you have. The members here will tell you or direct you to the forum topic that has a chart. Use a wire brush and solvent on a rag to get the axle tube really clean in order to see the code.
