Posted: Sat Sep 06, 2008 3:40 pm Post subject: priming fenders
Replacing front fenders because the current ones have rust holes in the lower rear corners near the doors, plus I got a good deal on replacement pieces to eliminate patching the originals. Is there a good primer/sealer to use on the inside of the new fenders before mounting them to hold off rust in the future?
Necoa #: 10393
Posted: Sat Sep 06, 2008 4:23 pm Post subject:
I painted as much of the inside as possible with epoxy primer, basecoat then clearcoat, then applied lots of cavity wax coating before fiiting them. _________________ Growing old is compulsory - Growing up isn't!
