El Camino Central :: View topic - ok, can't get carburetor on.
crmckinzey
Necoa #: 12273
PostPosted: Sat Sep 06, 2008 9:47 am    Post subject: ok, can't get carburetor on. Reply with quote
This time I have a picture. There is this silver circular object that prevents me from fitting the carburetor on. What do I do? Take the carburetor back?
pops86
Necoa #: 2793
PostPosted: Sat Sep 06, 2008 11:14 am    Post subject: Reply with quote
Looks to me like you have more problems than that. Are you getting off the computer controlled carb system?
Even if you went ahead and mounted the carb, it will not crank because it appears the computer system is intact. If it is, the distributor will have to be changed to an hei with a vac advance, or an aftermarket brand.
Looking at your picture, the power brake booster tubing line will have to be connected, which you will have to drill and tap the adapter plate unless the aftermarket carb has a fitting for it. The egr (shinny round thing) can be removed and an adapter plate bolted on.
It also looks like your tv cable is in bad shape and needs to be replaced. If it is not connected properly your tranny will crash.
Also make sure all the intake bolts are tight.
Hope this helps.
PostPosted: Sat Sep 06, 2008 11:17 am    Post subject: Reply with quote
That silver object is the EGR valve (Exhaust Gas Recirculation). There is a block-off plate available to eliminate it, but I would try to keep it. Personally I would spend the money to have the Rochester rebuilt rather than buy an Edelbrock. The Rochester is a good carb.
PostPosted: Sat Sep 06, 2008 11:23 am    Post subject: Reply with quote
pops86 is right, He replied while I was still typing. I did not address the other problems with this carb install. There are a lot of other considerations about installing a non-computer carb where a feed-back carb (computer controlled) was originally.
crmckinzey
Necoa #: 12273
PostPosted: Sat Sep 06, 2008 2:40 pm    Post subject: Reply with quote
bah damnit, so what should I do? here is a picture of the carburetor I have, says on the box cat. no 1406
crmckinzey
Necoa #: 12273
PostPosted: Sat Sep 06, 2008 5:19 pm    Post subject: Reply with quote
i'm going to just keep my rockchester, even the guys at the auto store said its the best and get it rebuilt. It may be the fuel filter in it that needs replacing. /shrug
Page Generation: 0.379 Seconds
