Posted: Tue Oct 07, 2008 4:10 pm Post subject:
Welcome to ECC.
Cut and remove the damaged areas, being sure to go beyond the damage. Then weld in some patch pieces, finish the areas, and resurface.
That is the correct process. _________________ http://elcaminocentral.com/gallery-album_CoyoteOn2s77Cage.html
Necoa #: 12570
Posted: Tue Oct 07, 2008 8:10 pm Post subject:
CoyoteOn2 wrote:
Welcome to ECC.
If the damaged area is small enough, you can use sheet metal of the same thickness from any source (scrap, an old panel from another area, donor car). If you need a whole panel, try Goodmark, OPG or Classic Industries. _________________
