El Camino Central :: View topic - Sea Foam, does it work?
jmchevy
Necoa #: 7649
PostPosted: Mon Sep 08, 2008 2:51 pm    Post subject: Sea Foam, does it work? Reply with quote
Been having a discussion at work about Seafoam, one guy says its really good for getting carbon out of an engine. Does it really work or just a ripoff?
pops86
Necoa #: 2793
PostPosted: Mon Sep 08, 2008 4:43 pm    Post subject: Reply with quote
In my opinion, Sea Foam, and Deep Creep, the aerosol version, are probably among the best on the market. At about nine bucks a pint it is pricy, but you get what you pay for.
ELBMINO
Necoa #: 9088
PostPosted: Fri Sep 12, 2008 1:07 am    Post subject: Reply with quote
what hose or vac hose do i use to deliver it to the intake?
''EAST-LB-MINO''
pops86
Necoa #: 2793
PostPosted: Fri Sep 12, 2008 9:37 am    Post subject: Reply with quote
I have sprayed it through the carb venturi, and through the pcv hose on car engines. On marine engines, spray through the enrichment valve (red knob) to winterize, or again through the carbs, saving about a quarter can to spray in each cylinder after removing the spark plug. Then let it sit overnight, blow out, place a little two stroke oil in each cylinder for lubrication, replace the plugs and run.
Hope this helps.
sandman
Necoa #: 3631
PostPosted: Tue Oct 07, 2008 9:58 pm    Post subject: Reply with quote
I'm the type of owner who does not believe in engine fixes/cures from a bottle. That said, my '79 with the original pos 305 smogmotor is carboned up from leaky valve guide seals and age. It runs and deisels on after shut off.
After reading positive feedback on Sea Foam, I've begun using it to see if it helps. Guess what? It's working. After running two cans through gradually (pour a little through the carb every week), I can hear and feel a difference. I'm pleasantly surprised, and therefore am recommending you give it a try...
Snaggle To0th
Necoa #: 4293
PostPosted: Wed Oct 08, 2008 7:23 pm    Post subject: Reply with quote
it works. We've used it for customers that barely failed smogs, after a full tank of gas and sea foam have been sucked through emissions have DROPPED significantly in most cases. Deep creep is awesome as well as a lubricant and penatrant. SEA FOAM WORKS USE IT!
Proud Wyotech Graduate
ELBMINO
Necoa #: 9088
PostPosted: Sat Oct 11, 2008 3:22 pm    Post subject: seafoam Reply with quote
need to know ,how to pour into the intake. i used in the gas already works
''EAST-LB-MINO''
Snaggle To0th
Necoa #: 4293
PostPosted: Sun Oct 12, 2008 2:45 pm    Post subject: Re: seafoam Reply with quote
Remove a intake manifold vacuum line with the engine running and LIGHTLY suck up the sea foam with the vacuum line you want it to suck it up so its a light mist going into the engine. Just a slight little slurping sound. Too much at a time can kill the engine so you have to start it up. And white smoke will come out of the exhaust too. Once you've sucked up about half the can let it continuing idling no reving the engine, let it idle. Once the smoke is gone your done! Reconnect the vacuum line.
-ANduh
ELBMINO
Necoa #: 9088
PostPosted: Tue Oct 14, 2008 10:03 pm    Post subject: Reply with quote
thx bud, but this line you talk about will be next to the intake manifold ? Confused
where at in the front or side of the intake? Thumbs Up Thumbs Up
''EAST-LB-MINO''
old_coot
Necoa #: 3943
PostPosted: Fri Oct 17, 2008 8:17 am    Post subject: Reply with quote
any vacuum line will do---the smaller the better though---like Snag says take it kinda slow and easy----I've even taken off the air cleaner and poured it into the carb while holding the engine at a good fast idle---maybe 1500 rpm just be sure to run it through both sides of the carb so all cylinders will get the benefit....I am also one of those that doesn't normally believe is extraneous chemicals in my engines but Sea Foam has made a believer out of me many times over
ELBMINO
Necoa #: 9088
PostPosted: Sat Oct 18, 2008 12:38 am    Post subject: Reply with quote
thx guys , this is why i love elco's & this site You Rock
''EAST-LB-MINO''
eastbayrider510
Necoa #: 12669
PostPosted: Wed Oct 29, 2008 2:45 pm    Post subject: Reply with quote
I just used SEAFOAM on my 86'.
I pour it directly through the carb while the motor was running (1 pint, roughly 2tablespoons at a time, any more and I could tell the engine would die), after pouring a pint through the intake, I poured a pint directly into my gas tank, then shut my car off. I then poured a pint into my crank case and lt sit for roughly 5 minutes.
Started my car, a BEAUTIFULL WHITE PLOOM of smoke flooded my parking area, lol. I let the car run for roughly 5 minutes, at that time the car was completely finished with its white farts...
I will have to say, no more dieseling, SOUNDS better (i think, in my bias ears, lol). A bit more crisp i'd say.
A MUST HAVE FOR ELCO OWNERS !
VOTE YES ON SEAFOAM! lololol
Rick
1986 Elco
Hayward, CA
http://www.cardomain.com/ride/3174341
ElkyHolik87
Necoa #: 12516
Year: 1968
PostPosted: Wed Oct 29, 2008 3:30 pm    Post subject: Reply with quote
WOWZERS I got to get my hands on this stuff, does autozone carry it? i'll find out. I know how to put it in the carb but im a lilttle scetchy about the vaccume hose's and puting it in my tank. could some one be so kind to post a pic of the hose's you put it in.
[img]http://i465.photobucket.com/albums/rr19/loom1
Bowtie
Necoa #: 4669
PostPosted: Wed Oct 29, 2008 4:57 pm    Post subject: Reply with quote
AZone has it. So does Advance and others. Just review some of the tips above from the gurus and follow the instructions. You'll have no prob. Worse case I've encountered took two cans. Still a bargain.
There are misc forums around that claim they have figured it out and make their own concoction. That's fine, just let them do it to their own car. Some folks will spend $30 to save $5. Confused
Take care.
84 Elky GTA
Page Generation: 0.361 Seconds
