El Camino Central :: View topic - End link nuts won't start. Threads hiding in bush
hawaii1984
Necoa #: 11592
PostPosted: Tue Oct 14, 2008 4:33 pm    Post subject: End link nuts won't start. Threads hiding in bush Reply with quote
Can't seem to get the bushings on a new set of end links to compress enough to get the nut started. Should the car be jacked with the tires suspended or should the car be up on ramps for this repair?
The sway bar is from a '87 Monte SS. Not the hollow one, but larger than my stock front bar. Hopefully it'll make a difference after wrestling those damn coroded/rusted/froze end links off. Now I am blessed with one stripped swaybar bushing bolt/hole as well...
Help/tips, please!
Scott
PostPosted: Tue Oct 14, 2008 5:21 pm    Post subject: Reply with quote
Suspension should be compressed or under load. If it still wont start get a longer bolt or cut the spacer down a bit.
hawaii1984
Necoa #: 11592
PostPosted: Wed Oct 15, 2008 12:06 pm    Post subject: short bolt Reply with quote
I mocked up the end link off the car and the threads only go 1/2 way through the nut. I should've saw this before. Thanks for the tip Tom. Gonna see if they have another set at redline and if not, the longer bolt will be the best choice.
Aloha,
Scott
texaselky
Necoa #: 10419
PostPosted: Wed Oct 15, 2008 4:27 pm    Post subject: Reply with quote
I had the same problem. I don't know if this is the right way , but what I did was set the car on the groung ang jacked up the sway bar till I could put the nut on.
1984 El Camino
Kyle, Texas
PostPosted: Wed Oct 15, 2008 7:07 pm    Post subject: Reply with quote
Mark, do you mean you jacked against the bolt head under the control arm?
texaselky
Necoa #: 10419
PostPosted: Wed Oct 15, 2008 9:04 pm    Post subject: Reply with quote
Yes, thats what I meant to say.
1984 El Camino
Kyle, Texas
greywolf
Necoa #: 64
PostPosted: Wed Oct 15, 2008 9:17 pm    Post subject: Reply with quote
I just went to the hardware store and got some threaded rod to make it as long as I needed. The original bolts were too corroded anyway.
hawaii1984
Necoa #: 11592
PostPosted: Thu Oct 16, 2008 2:17 pm    Post subject: End link rods Reply with quote
Thanks for all the tips. I went to Home Depot and they only have 8" rods which is what I already have. Then I called the local fastener shop, Hawaii Nut & Bolt and they have 8 & 10". I was looking for 9".
I will try and jack up the car under the control arm and rod bolt, but I think I need to find a way to clamp or strap and pull the bushings together for a little thread to start. I have never had issues like this with fron suspension, end links or anything... Confused
It's a test Mad
Aloha,
Scott
hawaii1984
Necoa #: 11592
PostPosted: Sat Oct 18, 2008 2:05 pm    Post subject: End-links finally on Reply with quote
Thanks for all the tips, but the fastener stores here only had the same size rod bolts as in the kit and my floor jack won't make contact with the bolt head so I:
jacked the car up, lowered the rod bolt head down onto the jack stand (not all the cars weight) then with a pry bar I pryed the swaybar down compressing the bushings till I had enough thread to start the nut. Amazing how easy it was once I was out of options.
Can anyone tell me if there are torque specs for the endlinks and what they are.
Again, thanks for all the suggestions... Cool
Scott
texaselky
Necoa #: 10419
PostPosted: Sat Oct 18, 2008 8:36 pm    Post subject: Reply with quote
Necessity is the mother of invention! Glad it worked out for you.
1984 El Camino
Kyle, Texas
Page Generation: 0.325 Seconds
